Mowing Rotary cutter with dual blades
   / Rotary cutter with dual blades #11
Right click the PDF link and select "save link as" and select the save point to someplace you can find the file, such as your desktop.
   / Rotary cutter with dual blades #13
It should work just like an image file.
If you go down to the "quick Reply" box, then click on "Go Advanced" there will be a "Manage Attachments" button below the text box, which indicates PDF is a valid file to attach.
The little icons above the "Quick Reply" may not work for a PDF.
Bruce
   / Rotary cutter with dual blades #15
I'm relatively sure when I right click on a PDF on JD parts schematic no "save as link" comes up. I'll look again. Thanks,Jim
   / Rotary cutter with dual blades #16
Sorry, sometimes I assume everybody's a Firefox user, IE users would select "Save Target As"
   / Rotary cutter with dual blades #17
I use Firefox.
UNUSED FUTURE CAT 301 EXCAVATOR ATTACHMENT SET (A57193)
UNUSED FUTURE CAT...
(12) SHEETS OF 3/4" OSB WOOD (A57192)
(12) SHEETS OF...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2025 HOOPER TRAILER SALES GOOSENECK TRAILER (A57192)
2025 HOOPER...
2018 Ford Fusion (A56859)
2018 Ford Fusion...
2016 Chevrolet Tahoe SUV (A54815)
2016 Chevrolet...
