Rotary Cutter rotary cutter shaft removal
   / rotary cutter shaft removal #21
the pto shaft broke and needs replaced Thanks in advance for any/all advice and suggestions.:confused:
Larry
This part pretty much answers that question...
David from jax
   / rotary cutter shaft removal #22
I can drag the bush hog close enough to get to it with a standard set of hoses, and I'll be drinking cold beer before you're done grinding... :)
I ran out of gas for the torch one day and needed to get a bearing off of a shaft on a haybine. I hooked it to my pickup truck and hauled to a friend's shop. He looked at it, went to get a drill and a chisel and a hammer and a puller and who knows what else. I grabbed the torch and by the time he got back with half his tools the bearing was lying on the ground in two pieces. The shaft was just barely too warm to touch... :)
Oh, and I wear hearing protection when I'm using the torch too - that way I can't hear myself screaming when the hot slag drops in my shoe... :D
Ah you still need a grinder...when you gouge a hole in the shaft with the torch... :D :D And don't say it can't happen!! :)
2017 MEC 1930SE 19ft Scissor Lift (A55851)
2017 MEC 1930SE...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
Rooster Weathervane (A55853)
Rooster...
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
