I'm in need of help! I have a Howse 5' bush hog, the pto shaft broke and needs replaced. The gear box shaft is smooth with a shear bolt. I have removed the bolt and also a c shaped spring clip from the end of the shaft. The end of the pto shaft attached to the rotary cutter gear box shaft now moves freely around it and back & forth, but it will not come off. I have tried everything including a come-along and a hammer. There is a small hole in the end of the gear box shaft but I was told that this has nothing to do with what I am trying to do. Has someone experienced this problem or can someone please suggest what I should do. I'm in a jam as until I replace the pto shaft the cutter is useless. Thanks in advance for any/all advice and suggestions.
Larry
			Larry
