Rotary Cutter rotary cutter shaft removal
   / rotary cutter shaft removal #21
the pto shaft broke and needs replaced Thanks in advance for any/all advice and suggestions.:confused:
Larry
This part pretty much answers that question...
David from jax
   / rotary cutter shaft removal #22
I can drag the bush hog close enough to get to it with a standard set of hoses, and I'll be drinking cold beer before you're done grinding... :)
I ran out of gas for the torch one day and needed to get a bearing off of a shaft on a haybine. I hooked it to my pickup truck and hauled to a friend's shop. He looked at it, went to get a drill and a chisel and a hammer and a puller and who knows what else. I grabbed the torch and by the time he got back with half his tools the bearing was lying on the ground in two pieces. The shaft was just barely too warm to touch... :)
Oh, and I wear hearing protection when I'm using the torch too - that way I can't hear myself screaming when the hot slag drops in my shoe... :D
Ah you still need a grinder...when you gouge a hole in the shaft with the torch... :D :D And don't say it can't happen!! :)
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
Chevrolet Metal Tailgate Art (A55853)
Chevrolet Metal...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
