Rotary cutter Help
   / Rotary cutter Help #1
maxchch
Lafayette LA.
Farmtrac 270 DTC
Hit a stump or 10 while using my Howse 400 cutter this weekend. PTO would spin at normal speed but blades would only turn slowly wile deck raised and not at all when lowered and faced resistance. Shearpin seemed intact although it would wiggle a bit by hand. Could use some input on any other things I could check or potential parts I may have torn up. I have limited knowledge as this is my first tractor. Also the plastic housing around the shaft has come apart. I can't seem to find just the protective plastic parts for the cutter shaft. Do I have to by a new shaft just to get the plastic tube and end pieces?
Thanks.
   / Rotary cutter Help #2
Did you have the proper shear bolt in and not a grade bolt?If you replaced the shear bolt with a grade bolt ,you may have 1.broke the pto on the tractor 2.broke the gear box on the BH...neither one is good.
Not sure. I bought the cutter used but it looks like a standard black bolt. PTO seems to be operating fine.
   / Rotary cutter Help #4
One thing to check. One of my cutters doesn't have a splined output shaft. It uses a keyed shaft for the blade holder. I've sheared that key before.
Exhibited the same symptoms. Everything was turning but the blades would stop once you hit anything.
Thanks. I'll check that as well.
   / Rotary cutter Help #6
ends of shear bolt may be struck an the shear pin is actually broken. Check and make sure gearbox is getting power.
   / Rotary cutter Help #7
ditto.
check to make sur einput shaft is spinning with pto.
black bolt? sounds hard to me?
if input shaft is spinning.. check blade carrier hub to output shaft as someone else mentioned.
post back
PS.. be carefull.. fon't get around spinning shfts or blades.. or get under an unsupported mower.. and concrete hollow cell blocks are not support. only solid jack stands rated for the weight ++and heavy timber..
Thanks everyone. My tractor is at my deer lease and we are expecting rain this weekend. Good for food plat, not so good for repair work. I'll post the outcome after I get a chance to work on it.
   / Rotary cutter Help #9
keep us posted on what ya find
   / Rotary cutter Help #10
My howse cutter has a splined shaft on the output side of the gearbox, the nut on the stump jumper has to be very tight and cotter pinned....just something else to check.
2020 Lincoln Naultilus SUV (A50324)
2020 Lincoln...
Land Honor Quick Attach Pallet Grapple (A50514)
Land Honor Quick...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
IH 490 Disk (A50514)
43006 (A51691)
43006 (A51691)
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
