Rotary Cutter Discussion
   / Rotary Cutter Discussion
just wondering if the deck height fell into the regular bush hog depth or that of a finish mower. regardless, you have a fine mower. do take care eventually removing blades for service, etc, always block the unit. i never crawl under the deck w/a grinder, recommend removing, clamp, & dress w/angle grinder, regards
& for tall stuff, i like to make 2 passes, one high, then low
I have a 40x60 shop being constructed as we speak. I have an Atlas 14k pound vehicle lift being installed... so, I "should" be able to maitain everytihing farily easily. I'm pretty excited about my shop... but, the weather has pushed everything to the right. Humph.
Ok Everyone… I finally got around to installing the front / rear chain guards on my Tractor Supply/County Line rotary mower.
I ordered these directly from Tarter, because Tarter makes them for TSC under the County Line brand name.
My unit is a 6’ rotary cutter, and Tarter confirmed that it is a 200 series. The chain guards are for the 300 series.
The front fit perfectly with zero modification. The rear did not.
I had to take out the lower bolt for the tail wheel brace, use clamps to hold the chain guard up, drill 3 of the 4 bolt holes and install. I also had to grind a little on the far corners to allow the outside most chain link to clear.
Not a bad job with a little bit of patience.
Now I feel a bit safer!
Cheers!
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2016 FREIGHTLINER...
2017 PETERBILT 579 SLEEPER TRUCK (A58018)
2017 PETERBILT 579...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB46449, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
2015 GMC Yukon (A56859)
2015 GMC Yukon...
2016 Ford Expedition (A56859)
2016 Ford...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
