ROPS light kit
/ ROPS light kit #1
drjay9051
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
Lots of threads on DIY work lights.
Has anybody used this complete kit which although is a more expensive seems like a fast way to install a kit.
Per owner the lights plug into the bullet connectors at the rear of the DK40.
I am very interested in this product just need some feedback from others
Kioti ROPS Lights LED Worklight Kits | ROPS Lights
Looks to be about 3,500 lumens total for 2 lights. Is that considered "bight enough" for tractor work?
/ ROPS light kit #2
I installed Rigid CREE lights on my Kubota BX25... purchased one 20" Spot light and two 4" flood lights... installed them on the ROPE bar... when I turn these lights on... I can position/direct them forward or to the back (when operating backhoe)... these lights are better than daylight... exceeded my expectations... below is link to Rigid Lights:
Rigid Industries LED Lighting | LED Lights, Offroad, Marine, Truck
You can purchase CREE lights on Amazon or Ebay... much cheaper... no doubt...
Hope this helps...
/ ROPS light kit #4
Kits are nice, but you can certainly do-it-yourself for far less money...and still have a great lighting system. LED's are the way to go!!!
/ ROPS light kit #5
That seems a little to expensive,I'd buy the lights separate,it should be a lot cheaper doing it this way.
/ ROPS light kit #6
Seems a bit expensive to me. I purchased a set of LED spot lights and everything needed to mount them at tractor supply and walked out with only spending a little less than half of what they want for that kit.
/ ROPS light kit #7
I considered that kit, but decided against on account of expense and the fact that additional materials are needed (you have to attached the wiring somehow for 1). For under $100 I mounted 3 LEDs (1 back, 2 forward) with a switch on the dash that looks factory made. 3 or 4 hours max time, could be done in less.
/ ROPS light kit #8
I put a set of leds, a switch, wire, and 'plastic armor' over the exposed wire on mine for less than $50.
2017 Toro GrandStand 52in Stand-On Mower (A64553)
2017 Toro...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
