ROPS canopy
/ ROPS canopy #1
kjg26
Buford, GA
2013 Kioti DK55
Im looking to add a sunshade/canopy to my ROPS. Looking for aftermarket options. Id prefer something stout...maybe something with a metal frame all the way around and then fiberglass.
/ ROPS canopy #2
Call your local dealership and see what they have. The ones close to me usually stock them. The dealership was actually the cheapest place I found to buy one.
/ ROPS canopy
What's everyone think about the Femco Inc Tuff Top?
/ ROPS canopy #4
I put a Femco Tuff Top on about 2 weeks ago and so far so good. Happy with it and seems well built. Instructions are not great though. A bit fiddly to assemble and I had to do some mods to get it mounted
/ ROPS canopy #5
I looked at them. Didn’t buy one because I haul my tractor from time to time and don’t want to take it off when I do.
/ ROPS canopy #6
I put a fiberglass canopy on my tractor a couple years ago. Nice in the summer. Only complaint - certain speeds and my driveway condition set up a vibration that is annoying. The solution - go either a little faster or a little slower down the driveway. Problem solved.
BTW - I got the canopy from the local Kubota dealer. Its actually a Kubota canopy.
/ ROPS canopy #7
I bought a Westendorf poly canopy. It's a two piece that's held together with 3M tape. It's supposed to be better than fiberglass because it will bend to a degree without breaking. It's also "easy off" which depends on your definition of easy. I just put it on the trailer backwards to tow, which isn't often. I really like it.
/ ROPS canopy #8
Masters Farm Supply in Florida. Aluminum diamond plate for fiberglass price. Ask for Carolyn. Google is your friend; I’m not connected with them in any way.
/ ROPS canopy #9
Two different types of canopies here.
Tractor canopies by Sun Guard and Rhinohide
They both have a quick removal set up.
They both have good videos from customers.
Both rated up to 60mph being trailered if not removed.
Plan on getting one also. Not even summer and already triple digits.
/ ROPS canopy #10
$50 golf cart canopy off the local Craigslist, plus custom-made (read homemade) metal frame.
/ ROPS canopy #11
^What Rick said. The diamond plate won't break when you bump a tree limb.
/ ROPS canopy #12
But it will bend. There is no canopy that can not be damaged. I have two Kubotas both with their fiberglass canopy and they are not hard to install but not an easy off. Have hauled both with no issues but those were not long trips or over 55 or so. Brother has MF with aluminum and has a few bends.
Had to have canopy made for side by side and bought the diamond tread aluminum, then had to find someone to bend it. Factory probably would have cost less if that was an option. In my looking the dollar difference between a good canopy and not as good one is not much. Buy best you can.
/ ROPS canopy #13
You’ll break several fiberglass or poly canopies before you bend the AL ones I’m referencing. They have a formed edge and are very stout. They may be FOPS certified when properly installed. Freight rates are affordable.
/ ROPS canopy
Ftg05. Please if you could send more pictures that would be great. I picked up a golf cart canopy yesterday. Now to figure out mounting
/ ROPS canopy #15
If you are working in the woods, skip the commercially made canopy altogether and have a Fab shop make you a FOPS (Falling Object Protection System) with Limb Risers.
Here is mine, made by a guy whose shop is just a few miles down the road from me (he can weld a whole lot better than I can.) My top is expanded metal, since I wanted the visibility, and protection from the sun isn't an issue in the woods. If I had it to do over, I'd put a solid top on it (I will do that at some point). I can remove it by pulling 4 bolts, but I never have. No need to take it of when hauling the tractor down the road - it's not going anywhere.
After working inthe woods with the Limb Risers, I wonder how I ever got along without them.
/ ROPS canopy #16
I looked at them. Didn稚 buy one because I haul my tractor from time to time and don稚 want to take it off when I do.
There's no need to. I thought that also and asked the dealer to take mine off;but they said it isn't necessary and would be a pain to put back on. They trailered it 50 miles to my mother's house where I hooked up my father's backhoe attachment; then it travelled 200 miles on a roll back ramp truck to my house, more than half of which was travelling up the interstate.
Nice job. :thumbsup:
/ ROPS canopy #17
Good to know. Maybe get get one for my ZTR.
/ ROPS canopy #18
Agree with the full FOPS, see my thread on the build.
http://www.tractorbynet.com/forums/customization/346672-jd-3005-full-cage-rops.html
/ ROPS canopy #19
/ ROPS canopy #20
I think this is the other one I have:
Cattle Catch Chute (A66408)
Cattle Catch Chute...
International 470 Disk Harrow (A66408)
International 470...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
Auger Cart (A65640)
Auger Cart (A65640)
RAYTREE RMPP680 HYD POST POUNDER (A64277)
RAYTREE RMPP680...
