Canopy ROPS / Canopy mounted fan
/ ROPS / Canopy mounted fan #1
TheCompound
Chickamauga, GA
JD1025R
Hi all! I'd like to add a fan to the ROPS or canopy on my JD 3038e. I've seen a couple of posts mentioning fan setups, mut very little real info and no pictures!
Have you mounted a fan to your open station tractor? If so, how? And would you share a photo and some tips?
Thanks!
/ ROPS / Canopy mounted fan #2
Mount an old radiator fan out of a late model vehicle up there!
/ ROPS / Canopy mounted fan #4
Fan? that's my air conditioner:laughing:
/ ROPS / Canopy mounted fan #6
Don't have a pic but I use a clamp on 12v fan, I think a 6". Got it from Walmart cheap, about $12. Surprised it works as well as it does.
What do you clamp it to? Or did you remove the clamp part and screw it to something?
/ ROPS / Canopy mounted fan #8
I have a "home built" canopy, the frame is made of 3/4 electric conduit. I clamp it onto that and run the cord down to the power port plug that is on the left fender. The clamp will just fit onto the ROPS also, then I blow it forward/down onto my neck. Works well.
/ ROPS / Canopy mounted fan #9
If I remember, I'll take a pic later
/ ROPS / Canopy mounted fan #11
Thank you everyone for the great and clear photos and conversations on this. Much appreciated!
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2012 Caterpillar CB54 Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2012 Caterpillar...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2022 John Deere 410R Sprayer (A63111)
2022 John Deere...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
