Root Removal
/ Root Removal #1
PSDStu
Platinum Member
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
I have 3 acres of land which we recently cleared. It was a thick forest and all the stumps were removed and a root rake was used to clean it up pretty well.
What we have left is a ton of small roots left over sticking up from the ground and need some ideas on the best way to remove them.
I was wondering if disking the ground, and then raking would work ok?
We plan on evenually planting centepide over the entire area.
Thanks!
/ Root Removal #2
I have the same situation after a recent property restructure due to a gas well drilling. I'm here as a interested observer! All help is appreciated........
/ Root Removal #4
Cultivation and raking and cultivation and raking and hand picking!! /forums/images/graemlins/grin.gif
Egon
/ Root Removal #5
How small? If they are so small as to not interfere with the smoothing of the land then I would leave them and just expect the first mowing to be a little rough. They will rot out in time. If they are so big that you can't smooth the grade and/or the mower will be damaged then you are going to need to rake them out. A heavy disc will chop them up into smaller bits.
ATS T460 Mini Skid Steer (A64047)
ATS T460 Mini Skid...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
JOHN DEERE 1520 - 15' GRAIN DRILL (A63291)
JOHN DEERE 1520 -...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
Pat's QH and hydraulic top-link.
Pat's QH and...
