Root Rake Grapple
/ Root Rake Grapple
I stopped by Mid State on Saturday to check out the grapples. They are stout. The grapple pivots on bolts instead of pins. No grease fittings and I couldn't tell if there were bushings. They would probably last me a lifetime. If I was using it everyday, I could add grease fittings or open up the holes and add bushings use pins instead of bolts.
/ Root Rake Grapple #12
For my limited usage they would likely last my lifetime too.
/ Root Rake Grapple #13
472N - You like the grapple from Mid State. No problem. Just every so often pull the bolts - grease heavily - reinsert. Good to go.
The problem now-a-days...... there are just too many choices. Guy has to be careful on the choices he makes. Has to be a wizard to remember what he had seen and reviewed on the internet.
/ Root Rake Grapple #14
I've had my 60 inch Land Pride grapple for over ten years now. I can say truthfully - width is not really that important. A 48 inch grapple will pick up most anything as well as a 60 inch, or larger, grapple.
I agree with oosik in this regard. Almost everything I handle is longer than the grapple is wide, many times, much longer. 12" longer would make little difference in the grapples ability to do its job.
Although, I have noticed with the 60" EA grapple on my L48, it would be easier to see the bottom outside corners if it was a 66" or 72" model.
Doug
/ Root Rake Grapple #15
Doug
Being able to see the sides of the grapple is a great point!
/ Root Rake Grapple #16
I would agree that a wider grapple would make "scraping the ground" a whole lot easier. The only time I would be doing this - cleanup after one of my large ancient pines came down. Pine bark beetle and wind.
Otherwise - I stand to see where the grapple tines are and go for it. Some times I'm too high - some times too low. Makes little difference. Go at it again and if I scuff things up - rear blade will smooth it all out.
My 80 acres is open range land. Also called the Scab Rock. There is nothing that I do that can not be corrected.
My only rule - keep that big thundering Kubota off my lawns. I have a JD 750 for lawn maintenance.
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
1973 White Trucks Western Star Dump Truck (A61165)
1973 White Trucks...
24in Hydraulic Auger Skid Steer Attachment (A59228)
24in Hydraulic...
2018 CATERPILLAR 420F2 BACKHOE (A59823)
2018 CATERPILLAR...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
