Root Rake Grapple
/ Root Rake Grapple #1
JPRambo
Platinum Member
Dahlonega, Georgia
kubota Bx23S, b6100
My son was asked to help an elderly couple to cleanup their yard. To cut back or remove a few very overgrown bushes and trees.he picked out a JD D110 and this attachment. He was wondering if anyone could tell him he possible manufacturer, year. I am hoping I can use it on my Kubota B7100. It obviously had been there for a few years by the rust on it it is pretty light weight. Son and G-son picked it up into the pickup truck.
/ Root Rake Grapple
a couple more pictures
/ Root Rake Grapple
/ Root Rake Grapple #4
That might be hard to tell the year made but it should fit your tractor . I would try to get all the old hyd oil out before I tried it on the tractor..
/ Root Rake Grapple #6
What's the most efficient way to drain the old hydraulic fluid?
Screw off the QCs ends and let them drain into a bucket?
Does this allow the fluid in the cylinders to drain also?
/ Root Rake Grapple
That is my question also. How would I go about draining the fluid?
/ Root Rake Grapple #8
Take the hose ends off or take them off the piston and you should be able to open and close the lid by hand and pump the hyd oil out
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
2016 Autocar ACX Xpeditor T/A New Way 31ASL 31Yd. Side Loader Garbage Truck (A66736)
2016 Autocar ACX...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2016 KUBOTA SVL75-2 SKID STEER (A65056)
2016 KUBOTA...
2017 Bobcat MT55 Ride Behind Track Loader Skid Steer (A66734)
2017 Bobcat MT55...
