root rake/grapple choice ??
   / root rake/grapple choice ?? #1
briandennis1470
   / root rake/grapple choice ?? #2
Another choice to look into is the BoDozer from Borford Mfg. Well built heavy duty.
   / root rake/grapple choice ?? #3
Welcome to tbn Brian,What is the lift capacity of your JD?
   / root rake/grapple choice ?? #4
How much is the Bradco?
   / root rake/grapple choice ?? #5
Quick Attach "Talon" , simply awsome for general cleanups but if your wanting to remove roots below the surface i'd go with the Quick Attach "Quick Claw" as the angle of the tynes on the "Talon" make it want to dig in at any oppertunity which makes the machine nose dive and dig ruts and can also overcome the relief valve in the control bank and make the grapple crowd under . The shorter vertical tynes of the "Quick Claw" would not have the same trouble .
Almac Fuel Tank Body (A51692)
Almac Fuel Tank...
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
1999 Hypac C-766 66" Double Drum Vibratory Roller (A52384)
1999 Hypac C-766...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
Valvoline 85/140 Gear Oil (A53117)
Valvoline 85/140...
