Root Grapple Drawings?
/ Root Grapple Drawings? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
I have been searching and I see a lot of guys have designed and produced their own root grapples. Does anyone have CAD drawings they would be willing to share? Any tips/pointers as I approach the design/fabrication?
ac
/ Root Grapple Drawings? #2
I ended up buying a great one from rootgrapple.com for my skid steer - pretty sure I couldn't put something together this nice for much less $$.
I've done the shopping, I'd prefer to fab. I need a winter project anyways.
I'm not a huge fan of the offerings on that site. I want a grapple that has hydraulics along the back like a 4 in 1 bucket. I already have a grapple bucket where the tops touch only the tip of the bucket and I don't like it. I want something more like a clam shell so I can pick up and squeeze logs and brush.
ac
/ Root Grapple Drawings? #4
I built my own with the help of my two sons. One does computor drawings and the other has a weld shop.
The tractor is a Dk55 and i can load logs or pick up about anything.
/ Root Grapple Drawings? #5
/ Root Grapple Drawings? #6
It takes a lot to put one together.
I used AR400 3/8 material then had the drawing and the plate sent out for lazer cutting. The plate was over $600. and the cutting was $175. We layed the drawing out so I could get everything out of a 4x9 ft sheet.
I bought two cylinders and other materials , Plate, tubing, welding supplys.
The easy part was welding it together.
The hyd. hoses are 3/8 from the valve in the rear of the tractor.
Hope this helps.
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
2022 EZ-GO ELITE...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2021 Kubota KX080-4 (A64126)
2021 Kubota...
