Rookie Question on 4 wheel drive
   / Rookie Question on 4 wheel drive #1
AKcold
LS XR3140HC
I have a XR3140HC and trying to get it out of 4 wheel into 2 wheel drive. Manual says depress clutch and push down on the selector on the floor for 2 wheel / 4 wheel.
Well I have hydrostatic so no clutch and the lever wont push down at all to select 2 wheel drive, dont want to force anything etc etc.
Any body else had this issue?
Thanks
   / Rookie Question on 4 wheel drive #2
Sometimes gently changing direction of travel while trying to disengage works.
   / Rookie Question on 4 wheel drive #3
It might be hard to shift into/out of 4WD if there is pressure on the gears. Try it on level ground where the tractor isn't trying to roll. Or try moving the tractor back and forth a little bit first. Or try putting the range selector in neutral first.
   / Rookie Question on 4 wheel drive #4
Try slowly rolling back and forth or lift the front end with the loader.
   / Rookie Question on 4 wheel drive #5
You need to balance the tire pressures so you are not wrapping the drive train up. Often we find that rear industrial tires only need about 12 lbs. Any more and you wind up with the problem you are having.
   / Rookie Question on 4 wheel drive #6
This.
Also if you have an FEL you can raise front tires off ground to "unbind".
Another technique is when rolling slowly, give the "go" pedal (hydro pedal, or throttle if gear driven) a tap then quickly release; at the same time push the 4WD selector lever at that sweet spot when the tractor is neither accelerating or decelerating when there's no tension in the drive lines and it should pop right out (or in) 4WD.
   / Rookie Question on 4 wheel drive #7
jack it up off the ground with the bucket and slightly tap the forward reverse pedal
Thanks I'll give it a shot, appreciate the help
   / Rookie Question on 4 wheel drive #9
I may be asking a supid question, but I am unfamiliar with the XR series. Is the 4wd lever actually on the floor? All the XG series have a "hand lever" for 2wd/4wd, the diff lock is on the floor. Am I learning something new?
   / Rookie Question on 4 wheel drive #10
Yes the lever is on the floor next to the diff lock. It would be nice if it were on the console.
Ford Bucket Van (A50323)
Ford Bucket Van...
Loader Arm (A51691)
Loader Arm (A51691)
2017 JOHN DEERE 350G EXCAVATOR (A51242)
2017 JOHN DEERE...
Quick Attach Log Splitter (A50515)
Quick Attach Log...
UNUSED FUTURE MINI SKID STEER PLATE GRABBER (A51244)
UNUSED FUTURE MINI...
2017 Kia Optima LX Sedan (A50324)
2017 Kia Optima LX...
