Rookie Question on 4 wheel drive
/ Rookie Question on 4 wheel drive #1
AKcold
Member
LS XR3140HC
I have a XR3140HC and trying to get it out of 4 wheel into 2 wheel drive. Manual says depress clutch and push down on the selector on the floor for 2 wheel / 4 wheel.
Well I have hydrostatic so no clutch and the lever wont push down at all to select 2 wheel drive, dont want to force anything etc etc.
Any body else had this issue?
Thanks
/ Rookie Question on 4 wheel drive #2
Sometimes gently changing direction of travel while trying to disengage works.
/ Rookie Question on 4 wheel drive #3
It might be hard to shift into/out of 4WD if there is pressure on the gears. Try it on level ground where the tractor isn't trying to roll. Or try moving the tractor back and forth a little bit first. Or try putting the range selector in neutral first.
/ Rookie Question on 4 wheel drive #4
Try slowly rolling back and forth or lift the front end with the loader.
/ Rookie Question on 4 wheel drive #5
You need to balance the tire pressures so you are not wrapping the drive train up. Often we find that rear industrial tires only need about 12 lbs. Any more and you wind up with the problem you are having.
/ Rookie Question on 4 wheel drive #6
This.
Also if you have an FEL you can raise front tires off ground to "unbind".
Another technique is when rolling slowly, give the "go" pedal (hydro pedal, or throttle if gear driven) a tap then quickly release; at the same time push the 4WD selector lever at that sweet spot when the tractor is neither accelerating or decelerating when there's no tension in the drive lines and it should pop right out (or in) 4WD.
/ Rookie Question on 4 wheel drive #7
jack it up off the ground with the bucket and slightly tap the forward reverse pedal
Thanks I'll give it a shot, appreciate the help
/ Rookie Question on 4 wheel drive #9
I may be asking a supid question, but I am unfamiliar with the XR series. Is the 4wd lever actually on the floor? All the XG series have a "hand lever" for 2wd/4wd, the diff lock is on the floor. Am I learning something new?
/ Rookie Question on 4 wheel drive #10
Yes the lever is on the floor next to the diff lock. It would be nice if it were on the console.
/ Rookie Question on 4 wheel drive #11
The 4wd lever is a bugger as you found out. The easiest way to get it to to engage or disengage is on the move.
/ Rookie Question on 4 wheel drive #12
Agreed! Just don’t do it while you’re tires are spinning or if you’re under load.
Well just an update......put it on a slope in neutral and let it roll a bit...held the brakes then popped it in and out of 4 wheel 2 wheel. Sure would be nice to have a light stating what it is in.
But yes it is really a pain to get change from 2/4 wheel
/ Rookie Question on 4 wheel drive #14
If it's a new tractor - should get easier with use.
Landhonor Quick Attach Power Rake (A66408)
Landhonor Quick...
Landhonor 11' x 19' Metal Carport (A66408)
Landhonor 11' x...
2008 SHOP MADE (A65643)
2008 SHOP MADE...
2019 RAM LARAMIE 1500 (A65643)
2019 RAM LARAMIE...
International 2000 Front-End Loader (A66408)
International 2000...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
