Rolling and Arresting Floor Mounted Drill Press Base.
   / Rolling and Arresting Floor Mounted Drill Press Base. #31
Terry, I know it's possible, but is it feasible to build something similar to what you used on your welding table maybe?? Something that can easily be raised onto the wheels for moving and settled back down on the pedestal for use?
Absolutely. For a heavy table either a pallet jack or a formed pocket to accommodate a heavy duty hand truck would work for lifting the “other “end.
One of those trailer mover dollies would work too. Just mount a hitch on one end or a formed pocket of some sort for the ball to lift.
We had two Target stores come to Victoria a while back. They both closed after two years. I tried to purchase one of the electric shopping cart movers but the local grocery chain guys wanted them more than I did.
   / Rolling and Arresting Floor Mounted Drill Press Base. #32
welding scrap metal art #Weldingart | Darbarīki in 219 | Welding bench, Welding table, Welding projects
I've rejected this idea in the past, partly because of a lack of swivel pads on the bottoms. It just occurred to me that the pads would be provided and time saved by cutting up cheap clamps to instead of using all-thread and connectors.
welding table plans #Weldingtable | Welding table in 219 | Welding table, Welding bench, Welding cart
I hadn't thought about putting casters on the threaded rods.
I'm envious at the order and space in some peoples shops. I'm taking advantage of the nice weather and working on stuff outside, because there's no room inside!
40' CONTAINER (A54757)
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A54756)
PAIR OF DIAMOND...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A55788)
2014 Peterbilt 337...
UNUSED FUTURE QUICK ATTACH PALLET FORKS (A54757)
UNUSED FUTURE...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A55788)
2017 Ford F-550...
