Rock removal
/ Rock removal #31
I know the original Poster has limited tools, but one method I use that limits rock picking (the worst job there is on a farm except maybe grabbing retained afterbirth inside a dairy cow), is to deep plow with a turning plow, then dragging the surface smooth with a log. Dragging the widest, biggest log the tractor can tow works best because it makes for a smoother area because the log spans such a wider area, cutting off hills here and filling depressions there.
The roundness of the log works well because it presses the rocks into the soft soil instead of popping them up like a disc harrow. The bigger rocks have to be picked of course, but it is a lot less of them. The key is deep tilling to give a place for the rocks to go. I was told frost action would just push the rocks back up, but this has not been my experience at all with fields reseeded for hayfields and pastures. The sod helps hold them down.
Note: I am using a skidder here, but it was a big long log. Just scale the log back to the size tractor you have.
/ Rock removal #32
N2, I am about 50 miles east of you and know exactly what you are dealing with. Red dirt + hard rain= ground on which nothing but weeds and gullies will grow. Even if you had a good cover of straw it would have been hard to keep that from washing down the hill. About the only thing that will stay put is the erosion matting and that is so expensive.
I do have a dump trailer, but the main difficulty is still making the rocks and limbs go from the ground into it. A grapple is good (I have one) but it does not do everything as you accurately noted.
You have probably noticed that when you are bushogging you will build up a lot of chaff and seed on it on the cutter. At the end of the day, drive over to your red ground and take a leaf blower and blow off all of the chaff on to the ground. I guarantee that within six week s if you get any rain at all you will get a nice green cover. Of course it will all be weeds, but any vegetative cover is better than none. :D. Good Luck. W. Jones
That is definitely a good idea to get something started and I am going to have about 12 acres to mow around August when everything "tops out" and goes to seed so I should have plenty.
We don't keep cows of our own anymore but are loaning the pasture land to some family and in the winter they feed round bales without a ring/feeder so once the cows eat it down so far, they start stepping in it & crapping on it and don't eat anymore - which leaves several large mounds of grass killing hay rot all over our fields. I usually take the landscape rake & grapple to clean it up & pile it on the burn piles. I'm toying with the idea of seeing how much of that I can pick out and cover over the dirt areas and then possibly even use a disk harrow (set straight) to try to cut/mulch it up some.
/ Rock removal #33
OP is putting in a garden, not a pasture.....
/ Rock removal #35
But it gives some of us who may be contemplating rejuvenating old pasture fields or just putting in large food plots for the wildlife helpful ideas. ;)
There are very few topics on this forum, or any forum for that matter, that don't stray a bit from the original question or comment.
/ Rock removal #36
My ground is rocks with just a bit of dirt... why they call it the rocky mountains i guess! It doesn't make for the best gardens and I've tried to rake them after tilling but that doesn't work. I have resorted to tilling and sifting through a grizzly and then bringing in manure to replace the lost volume .
Anyone know where to get hands on an attachment like this in the USA? Looks like a tiller but buries the rocks.
ENFOUISSEUR EPIERREUR MASSANO RSE 3 euroagrimat.fr - YouTube
Massano, interratrice rotostone al lavoro - YouTube
/ Rock removal #37
The trouble is (unless you have thick sod on top, like in a pasture) the rocks won't stay buried because of freeze/thaw.
So much easier to just start piling on organic material and forget plowing and tilling.
Our mountain "soil" is also rocks held together with a little red clay. After a couple of years of very little work, just dumping on more material, my garden plot has over a foot of rich, dark brown soil, and earthworms galore. This sits on top of the existing soil, I never attempted to work it in, or plow it under. In fall it gets another thick layer of shredded autumn leaves. In spring, scrape it off to the side, into a pile to finish composting, and plant. Simple/easy.
/ Rock removal
So now I have a 3' high berm where I've been pushing top layer to one side trying to push rocks. Lots of rocks, but also lots of good dirt in there too. Can I rent a rock bucket somewhere like Hertz or Sunbelt? Sifting through all that would give me tons of large rocks I could use in erosion areas and then a big pile of clean dirt. $800-$1000 for the cheapest 72" I can find online - don't want one that bad.... But use of one for a weekend or so would be nice.
/ Rock removal #40
You're closer to winning the battle then you may think. Now you can make a grizzly... a screen that's higher on one end so that as you dump your material the soil falls through, while the rocks roll down the front of the screen. This link Portable Soil, Topsoil, Rock and Gravel Screeners is for demonstration purposes.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2005 JLG 600S 4x4 Telescopic Boom lift (A59228)
2005 JLG 600S 4x4...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A59231)
2023 Fat Truck...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2016 Ram 4500 Crew Cab Landscape Dump Truck (A59230)
2016 Ram 4500 Crew...
