Rock bucket
/ Rock bucket #1
jrlandscaping
How well do these rock buckets work? After prepping and final grading I end up with a sometimes rather large pile of weeds / rocks which is difficult to pick-up with the bucket without bringing up a bunch of soil as well.
/ Rock bucket #2
The vertical fins inside the bucket will tend to catch & hold debris when dumping. Clumps of sod will not drop thru, spacing is too close.
A small bump vs fin will allow full dumping of the bucket. wider spacing allows clumps to drop thru.
This bucket design is more robust when digging than say a manure fork where the tines are unsupported & tend to bend out at the ends.
/ Rock bucket #3
I always thought one of these buckets would be handy, just rake your junk into a pile, scoop it all up give it a couple shakes to get the goodness out, and go get rid of the junk!!
/ Rock bucket #4
I have the rock bucket made by Millonzi and am happy with it. Digging out rocks then shakin' out the dirt works well. Just don't be downwind when you do the shakin' !!!
/ Rock bucket #5
I've got a little experience using one. As others posting have mentioned sod and even damp earth will clump up and hold the rocks in the bucket unless you shake like crazy, which is inefficient and will punish all of your loader wear points. Really, something like a power rake or rotadairon is needed for finish landscaping.
Still, not wanting to bend over and pick up a lot of rocks, especially the heavier ones, I had one built by a local welder using a worn out bucket for fraction of the cost (about $400). The spacing is wide: about 6". I found the best way to use it is with the bucket angled about 30-45*, drive forward and comb the rocks out of the soil. I rarely lift and shake anymore.
/ Rock bucket #6
There are other designs that look like they'd work better, Jinman has one on his.
213130 (A64276)
213130 (A64276)
2014 Caterpillar 304E Mini Excavator (A66734)
2014 Caterpillar...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
PALLET OF 2CYL GAS ENGINE/RADIATORS AN PARTS (A67714)
PALLET OF 2CYL GAS...
BODY LOAD TANK (A67714)
BODY LOAD TANK...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2016 Chevrolet...
