Robin Subaru Engine Problems With Solutions
/ Robin Subaru Engine Problems With Solutions #81
Problem #: 2
Problem: Engine does not start when cold. It cranks normally.
Safety Concerns: Normal care about rotating parts. Wear safety glasses.
Test: Crank engine with choke on. If it does not start remove air cleaner and verify that the choke is closed. Manually try to close choke if needed at carburetor. (The choke is closed with a spring and may erratically stick open). If it starts then this is the problem.
Solution: Try cleaning the choke assembly with carburetor cleaner. If this does not work do this.
Close choke and remove the screws that hold the coke plate to the choke shaft. (Be very careful not to drop the screws in the carb. You might want to put a piece of tape on the choke plate hole) Observe how the choke spring is installed. Remove the choke plate and pull the choke shaft out. Clean the shaft, choke plate, and holes that the shaft when through and reassemble. This problem was erratic and once I manually closed the choke it would be OK for awhile. The next monring it would not close.
I'm having this issue with 3 robin subaru engines. Fuel tank clean and serviced, new fuel filter and line, new oem carbs. Above 60 degrees pull choke start up and runs. Around 40 degrees and under pull choke have to hold for extended amount of time cranking once it starts have to still hold choke until starts to idle on its own. Even then sometimes if choke released it stalls out. Choke is working properly
2013 FORD TRANSIT CONNECT VAN (A66091)
2013 FORD TRANSIT...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2008 SHOP MADE (A68842)
2008 SHOP MADE...
5103SFL (A64553)
5103SFL (A64553)
2006 INTERNATIONAL DURASTAR 4300 (A67714)
2006 INTERNATIONAL...
2016 CHEVROLET IMPALA CAR (A66091)
2016 CHEVROLET...
