Robin Subaru Engine Problems With Solutions
/ Robin Subaru Engine Problems With Solutions #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
We have had complaints about problems with the Robin Subaru engines.
I would like this to be a thread that someone could use to quickly find a solution to an engine problem. Let's try to keep this to solutions that you are sure of and have personally tested. Here is the example format.
Problem #: 1
Problem: Engine runs on one cylinder, runs rough at all speeds and stalls when idled.
Safety Concerns: The spark on the ignition coil can give you a nasty shock. Handle with care.
Test: Run engine at medium speed. Pull one plug wire and see if engine stops. If it keeps running put that wire back and pull the other plug wire. If it stops there is a problem with the ignition on that side. Test for a spark by putting a screwdrive in the spark plug wire cap. Hold a portion of the screwdriver near a ground, crank the engine. If there is no spark then the ignition coil or wire is bad or the magnets are dirty. If there is a spark then check the spark plug.
Solution: I found a bad ignition coil. It was originally erratic but then failed completely.
Problem #: 2
Problem: Engine does not start when cold. It cranks normally.
Safety Concerns: Normal care about rotating parts. Wear safety glasses.
Test: Crank engine with choke on. If it does not start remove air cleaner and verify that the choke is closed. Manually try to close choke if needed at carburetor. (The choke is closed with a spring and may erratically stick open). If it starts then this is the problem.
Solution: Try cleaning the choke assembly with carburetor cleaner. If this does not work do this.
Close choke and remove the screws that hold the coke plate to the choke shaft. (Be very careful not to drop the screws in the carb. You might want to put a piece of tape on the choke plate hole) Observe how the choke spring is installed. Remove the choke plate and pull the choke shaft out. Clean the shaft, choke plate, and holes that the shaft when through and reassemble. This problem was erratic and once I manually closed the choke it would be OK for awhile. The next monring it would not close.
Problem #: 1
I have an error in the above post. The corrected Test: section is below.
Test: Run engine at medium speed. Pull one plug wire and see if engine stops. If it keeps running put that wire back and pull the other plug wire. If it runs there is a problem with the ignition on that side. Test for a spark by putting a screwdriver in the spark plug wire cap. Hold a portion of the screwdriver near a ground, crank the engine. If there is no spark then the ignition coil or wire is bad or the magnets are dirty. If there is a spark then check the spark plug.
I am hoping others will post issues here. If they think this is valuable. Maybe it's not.
/ Robin Subaru Engine Problems With Solutions #5
If you pull a plug wire and it makes no difference, THAT is the defective side (it is not firing, hence pulling it makes no difference).
That's right. Thanks for the clarification.
/ Robin Subaru Engine Problems With Solutions #7
I have a robin subaru EX27 9 hp engine on a portable backhoe that can run from for the first 1hr to 45 mins and will just stop. I can get it started with one pull and it will run for another 5 mins to 30mins. It usaully doesn't happen for the first 45mins, but once it happens then it will keep happening the rest a of the day Any ideas on the problem.
/ Robin Subaru Engine Problems With Solutions #9
Thanks for the reply. Definitly not gas cap had that problem on a generator once so I am on top of that issue. It still happens when the cap is loose and well vented. Is there any thing I can do for the vapor lock? I thought vapor lock only happen after you stop the engine
/ Robin Subaru Engine Problems With Solutions #10
The mechanical fuel pump is mounted on the cylinder head. Close proximity between it and the muffler can cause it to vapor lock. You can move the fuel pump anywhere you want (it is pulse driven off crankcase vacuum, not using a mechanical linkage).
Also look at how the fuel hose is run. If you put some heat shielding around it (or just user thicker hose), it can partially solve tis problem.
Big assumption here; I am describing the robin 22hp engine, not the 9 hp version.
Does the 9HP have a fuel pump?
/ Robin Subaru Engine Problems With Solutions #12
Bob do you have any ideas [/SIZE ]
/ Robin Subaru Engine Problems With Solutions #14
You can look at the ex27 manual and pictures at robinamerica.com
Definitely no fuel pump, just gravity fed. I retract my previous vapor lock guess. Not the same problem we have with PT 422s. Close proximity of fuel tank and carburator makes vapor lock less of an issue.
Low oil pressure shutdown sensor? Maybe that is giving you your problem?
/ Robin Subaru Engine Problems With Solutions #15
Oil is filled to the top and wouldn't the problem happen right away? The engine runs for 1hr - 45mins before it starts acting up
/ Robin Subaru Engine Problems With Solutions #16
I was thinking more that maybe the sensor was faulty. It heats up, and then triggers a shutdown. Oil sensor was optional for your engine (based upon my brief read of the manual... I am not a smallmengine expert and I did not stay at the Holiday Inn Exprsss last night).
Look at page 55 of the service manual:
http://robinamerica.com/media/manuals/129042630160998465.pdf
I am not sure how to hot wire the sensor... Either ground the wire or leave it detached and see if the engine stays running.
/ Robin Subaru Engine Problems With Solutions #17
Looking at the manual an open (disconnected) would fake a good oil level. However that sensor is a magnetic float triggered reed switch and I doubt it is temp sensitive, but worth a try. There is a "black box" associated with the oil sensor that could be bad...what puzzles me is the diagram shows an LED output...so what powers it? Unless it is the electric start version with a battery -If the engine isn't running it has no electric power available.
Since the engine has a solid state igntion I'm thinking a component is temp sensitive and heating up.
Next time it quits perhaps JimmyJohn could check and see if it still has spark.
/ Robin Subaru Engine Problems With Solutions #18
i got the eh65 subaru Vtwin engine.
it runs on one cylinder i switched the coils around and it still runs bad on the same cylinder.
it keep fauling up the plug and i have the same amount of compression on both sides.
would the Igniter be bad?
would greatly aprecciate the help to find whats wrong with this engine.
I don't understand the term igniter. Did you swap the ignition wire with the coil? Do you have the gap set right between the coil and the rotor? Is the plug oily or black soot covered?
/ Robin Subaru Engine Problems With Solutions #20
the sparkplug doesnt really have the black soot on it so it isnt a oil burner.
it just has to weak of a spark on the one side and the coils are good.
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2019 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2019 Kubota...
Bomag Roller (A63689)
PALLET OF MISC JACKS AND JACK STANDS (A67714)
PALLET OF MISC...
2014 Chevrolet Impala Sedan (A66738)
2014 Chevrolet...
