Robin same size as Kohler?
/ Robin same size as Kohler? #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
Does anyone know if the Robin engine is the same physical size as the Kohler engines Power Trac used previously. As luck would have it, I have a 25 HP Kohler in my garage that came out of a 2002ish vintage 425 (I bought the tractor originally and sold it to my neighbor when I bought my 1845). If anyone has a Robin laying around they can measure, we could compare the two engines. I suspect they would be interchangeable. Personally, I much prefer the Kohler due to easy cold starts, easy to find parts and service, and proven reliability. I'm not dissing the Robin....I just like the Kohler a bit better.
/ Robin same size as Kohler? #2
Hopefully this pic will help:
/ Robin same size as Kohler? #3
As far as I can tell,the Robin is significantly shorter front to back than anything else in the 25hp class. I think the next shortest is over an inch longer, maybe an inch and a half. Most are a fair bit longer than that.
I'll research this a bit this weekend and report back...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
429643 (A61165)
429643 (A61165)
2024 Kubota SVL97-2, PIN: KBCZ064CJN1J72104 (A61166)
2024 Kubota...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
2024 OMEGA 2700S WHEEL LOADER (A62129)
2024 OMEGA 2700S...
Pabreak 84in Hydraulic Serrated Dozer Blade Skid Steer Attachment (A61567)
Pabreak 84in...
