Robin same size as Kohler?
/ Robin same size as Kohler? #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
Does anyone know if the Robin engine is the same physical size as the Kohler engines Power Trac used previously. As luck would have it, I have a 25 HP Kohler in my garage that came out of a 2002ish vintage 425 (I bought the tractor originally and sold it to my neighbor when I bought my 1845). If anyone has a Robin laying around they can measure, we could compare the two engines. I suspect they would be interchangeable. Personally, I much prefer the Kohler due to easy cold starts, easy to find parts and service, and proven reliability. I'm not dissing the Robin....I just like the Kohler a bit better.
/ Robin same size as Kohler? #2
Hopefully this pic will help:
/ Robin same size as Kohler? #3
As far as I can tell,the Robin is significantly shorter front to back than anything else in the 25hp class. I think the next shortest is over an inch longer, maybe an inch and a half. Most are a fair bit longer than that.
I'll research this a bit this weekend and report back...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
John Deere 5101E Tractor w/ John Deere Loader (A64047)
John Deere 5101E...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2015 FREIGHTLINER MID ROOF SLEEPER TRUCK TRACTOR (A59910)
2015 FREIGHTLINER...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
