road railing
/ road railing #1
eteagle
Illinois
JD 3300
A section of my gravel road is truck width where it passes over a culvert that is quite deep. Would like to place railings either side of road. Any advice as to materials and tips would be very welcome. Thanks.
Ernie
/ road railing #2
I see you haven't had a response here, and was wondering if simulating a guard rail like they put up for highways would be possible for you?
Maybe some treated 6 - 8" posts in the ground every 8 feet, with some treated 2x10's bolted on for fender bumpers would possibly work.
/ road railing #3
I just saw an ad for some of that very material used. If you're interested, email me and I'll get you the contact info. I hope this helps.
/ road railing #4
Might use surplus telephone poles, or similar.
Is this a private road, or a municipal road ( including recorded prescriptive road )?
If not private, you may not be able to do this... check with your local municipality.
Soundguy
/ road railing #5
I see a lot of gard rails on hiways these days use wood posts, with Armco atached to it. Now the armco[that sideways W shaped stuff] is not that easy to find, but for your use, channel iron should get the job done. Just sink some 6x6 post, lag a lenght of chanel on, and your set. Spaceing would depend on the lenght of the steel. If you can get 10 footers, I would put a post on each end, and one in the middle. That should do it. Now this isnt a high speed road is it? If so all bets are off.
/ road railing #6
<font color=blue>"the armco[that sideways W shaped stuff] is not that easy to find"</font color=blue>
I believe there are some used ones available around here if anyone needs or wants any.
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
3pt 4 Row Bottom Plow (A64119)
3pt 4 Row Bottom...
2022 EZ-GO ELITE...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
