road railing
/ road railing #1
eteagle
Illinois
JD 3300
A section of my gravel road is truck width where it passes over a culvert that is quite deep. Would like to place railings either side of road. Any advice as to materials and tips would be very welcome. Thanks.
Ernie
/ road railing #2
I see you haven't had a response here, and was wondering if simulating a guard rail like they put up for highways would be possible for you?
Maybe some treated 6 - 8" posts in the ground every 8 feet, with some treated 2x10's bolted on for fender bumpers would possibly work.
/ road railing #3
I just saw an ad for some of that very material used. If you're interested, email me and I'll get you the contact info. I hope this helps.
/ road railing #4
Might use surplus telephone poles, or similar.
Is this a private road, or a municipal road ( including recorded prescriptive road )?
If not private, you may not be able to do this... check with your local municipality.
Soundguy
/ road railing #5
I see a lot of gard rails on hiways these days use wood posts, with Armco atached to it. Now the armco[that sideways W shaped stuff] is not that easy to find, but for your use, channel iron should get the job done. Just sink some 6x6 post, lag a lenght of chanel on, and your set. Spaceing would depend on the lenght of the steel. If you can get 10 footers, I would put a post on each end, and one in the middle. That should do it. Now this isnt a high speed road is it? If so all bets are off.
/ road railing #6
<font color=blue>"the armco[that sideways W shaped stuff] is not that easy to find"</font color=blue>
I believe there are some used ones available around here if anyone needs or wants any.
2014 Hyundai Sonata Hybrid Sedan (A61574)
2014 Hyundai...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
(2) FORESTRY TIRES ONLY (A64276)
(2) FORESTRY TIRES...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
