RK24 Rear Remote Control
/ RK24 Rear Remote Control #1
OhioCowboy
N. Ohio
KIOTI CK3510se HST Open Station w/FEL, RK24 HST w/FEL & Backhoe, DEAD-NH TC33D HST
What am I missing? :confused:
I have a lever for the lift arms on the right and on the left side I have a lever for 2wd/4wd, a lever for hydrostat hi/lo, and a lever for the PTOs. No lever for the rear remotes?
/ RK24 Rear Remote Control #2
Not sure if they have changed it. But the couple that i have seen have the lever mounted on the right side of the ROPS. Not sure if they changed the location. Found this picture I circled the lever. IMG_2235.JPGIMG_2236.JPG
:ashamed: :lightbulb: Forgot all about it being there. I removed it on day one because I knew it was going to get bent or broken getting on and off. The FEL lever is bad enough for me by blocking half the entry. Actually, I'm trying to figure out how to move the FEL back to the right side of the seat or at least hinge it so I can move it out of the way when I'm not using the FEL. Thanks for waking up those brain cells!
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
New/Unused 12 Ton Hydraulic Jack (A65583)
New/Unused 12 Ton...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
(3) Pieces of 30' Sticks of Heavy Wall Poly Pipe (A62679)
(3) Pieces of 30'...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
