Backhoe Ripper tooth design - need your advice
   / Ripper tooth design - need your advice #71
If all goes well I'll be testing it out last week of October... pics will be posted early November. Got about 2 dozen stumps to eliminate so we'll see how I do.:thumbsup:
Expect a learning curve. Smaller stuff with just rip out but bigger stumps and roots require some strategy. Basically, either work at the root close in buy chewing at it or driving the point through it or alternatively, pivot the BH away from the stump and rip the root a few feet away where it is smaller. On big stumps I work around them by changing tractor position by 90 degrees after ripping the roots I can easily reach. Keep moving around rather than stretching to reach. Don't try to rip a big root with the BH fully extended as you won't have as much leverage. Use both curl on the ripper and pulling with the dipper or up with main boom. You'll probably develop your own style just try different techniques. It is not simply like digging with a narrow bucket. Also, check the stability of the stump occasionally by putting the ripper over it and pulling. Two things to look for: first is how loose it is and second is to judge where the remaining stabilizing roots are based on how it pivots. I actually only rarely use the ripper to completely remove the stump. Once it is good and loose, I turn the tractor around and get the grapple under then use low range to push and lift. Often faster than completing the job with ripper alone. Besides, you will need the FEL end to move the stump anyways so don't hesitate to use the one two punch. It can also help identify the one root that needs more ripping. On a big stump I might reposition half a dozen times and
push with the grapples a time or two before winning.
And the rest of the equipment too!
Holy crap Blue, nice fab work! Almost be a shame to get it dirty or scratch it
I have been getting a lot of feedback from fellow employees... everyone is excited about the fab. Got the final welding done and will post pics probably tomorrow. I need to see if I can get it into the sandblaster so I can clean it up and get a few coats of paint on it before inauguration day :D
   / Ripper tooth design - need your advice #73
The paint won't last long.
I have printed your comments and will stick them in my backhoe manual tube so I make sure I have them with me. I'm looking forward to practicing the technique in the field. I know there will be a learning curve and I accept the challenge as these stumps gotta go! I also have purchased four 12" sawzall wood blades for those difficult roots that won't cooperate. I really appreciate the time you put into verbally training us newbies and all the suggestions as well. You are a long ways away from me... but I owe you a few :drink:
Almost complete... just have the pin bores to cut to size. Hoping to complete early this week if the machine is available for me to use after work hours. My welder friend (Ron S.) did an awesome job providing welds that will outlast not just mine but my grandkids needs! :thumbsup:
The tip came out as I had hoped with the welds filling in the chamfers I had provided (I was a bit concerned about this ). I was hoping to put some "hardface" welds on the tip & cut edge prior to the first use... but it looks like that may have to wait until later, unless I can find a local source for a small quantity of rod (I don't need 10lbs, the good stuff is pricey!)
Ripper_9_fabC.jpg Ripper_9_fabC-2.jpg Ripper_9_fabC-3.jpg Ripper_9_fabC-4.jpg Ripper_9_fabC-5.jpg Ripper_9_fabC-6.jpg Ripper_9_fabC-7.jpg Ripper_9_fabC-8.jpg
   / Ripper tooth design - need your advice #78
IslandTractor - I followed your thread before. What is the largest stump you've managed to dig up to date? I'm looking at a new tractor in the future and I could get a small CUT and a Mini-Ex or a larger tractor with basically a BH90x.
Wedge
   / Ripper tooth design - need your advice #79
IslandTractor - I followed your thread before. What is the largest stump you've managed to dig up to date? I'm looking at a new tractor in the future and I could get a small CUT and a Mini-Ex or a larger tractor with basically a BH90x. Wedge
It was an oak. Diameter was a few inches less than 36" at waist height as I recall. Took a few hours to dig out. It was big enough that I couldn't lift it out of the hole and needed to use the BH to drag it out but then I could lift it a foot or two with grapple. My grapple opens about 46" and it was pretty full as I recall.
   / Ripper tooth design - need your advice #80
I just dug out a stump from the driveway ditch at my flip property. I leave a bout two feet of stalk on stumps i know I'm going to be ripping out. This gives me the ability to use the stalk to leverage the stump and roots to see what is still holding the stump in the ground. In this case I was close to a maple I wanted to save on the upside bank above the stump. So I had to not disturb the maple's roots any more than necessary. I find if I can uncover the main roots or the tap root by using the ripper to scrape dirt away from the stump it gives me better ability to position the hoe where it is needed to accomplish the least effort and faster results. Periodically I will use the bucket of grapple to push or pull on the stalk to access what is left to rip. In this case in low range with diff locked I was able to force the stalk over and break the remaining roots by shear force of will and some tractor muscle. I find stumps that I have cut and left for some time will often break free sooner than ones recently cut. This is usually because the stump and roots have begun to die and harden and hard roots are more likely to give way under pressure than live ones, IMPE. New acronym: In My Personal Experience, (IMPE). BTW, getting off the tractor to use a sawzall blade is not allowed! International rules of stump removal prohibit any getting off the tractor or leaving the stump for anything but 1 10 min break per 2 hrs competition time frame.;)
I was wondering if you have a finished weight of your stump slayer? It looks good, but heavy to move around...
JOHN DEERE 6000 SERIES BRUSHGUARD (A57192)
JOHN DEERE 6000...
2018 Infiniti QX60 AWD SUV (A55853)
2018 Infiniti QX60...
2014 Evans 48' Drop Deck Trailer (A56469)
2014 Evans 48'...
Portable Restroom (A54865)
Portable Restroom...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
