Ripper(?) Repair
/ Ripper(?) Repair #1
rvaitor
Platinum Member
Nashville, TN / Hickory, NC
Kioti DK55C
I'm not sure this is a ripper, but it is missing some prongs/teeth. I am figuring 3 of 9. First question is where can I find these? What exactly is this used for? I am wanting to rake some roots, debri up from a field I am clearing before disking.
Thanks for the help.
/ Ripper(?) Repair #3
With those bolt on tine brackets, it looks like some type of row cultivator that you can adjust the position/width to go between planted rows. I don't know about direct replacements, but you might try
Agri Supply - Where we have Something for Everyone for your Farm Shop & Home
Look under "AG & Tillage" and "tillage" I found reversible cultivator points in a quick look. They also have landscape tines at a very reasonable price, so you could probably replace the whole assembly if you are going to be using it for rakeing anyway.
They are great people to deal with in my experience. If you need specific info on a part, give them a call. When I was building a landscape rake, they E-mailed me the manufacturers spec drawings for the rake tines. For a smaller rake project, they sent me a sample tine free of charge to test fit on my frame.
/ Ripper(?) Repair #4
That is a cultivator and pic shows 2 bolts in the sweep? If so, any store that sells field cultivator sweeps such as TSC should have replacements just as long as the bolt centers are the same.
/ Ripper(?) Repair #5
we have a ford cultivator with similar spring shanks
/ Ripper(?) Repair #6
If that is in Nashville, I think you should just get rid of it, that old rusty thing should not be around, matter of fact, I may be able to help you out of this dilema :)
But really, any of the tractor shops have those or can get them through Tisco or similar. Everyone seems to have a slightly different name for them but just bring in an old one and they can match you up.
I use Red River Equipment up here in Clarksville, and he keeps several types sizes etc. on the shelf.
/ Ripper(?) Repair
Alan, Thanks for the offer, but it's in NC. Probably cost more to ship than it's worth.
I'll check out the local farm supplies over there.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
IH IC70-2 RUBBER TRACKED CRAWLER CARRIER (A65056)
IH IC70-2 RUBBER...
CAT R500/D9R Ripper Teeth (8) (A68134)
CAT R500/D9R...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2015 BIG TEX T/A UTILITY TRAILER (A67714)
2015 BIG TEX T/A...
2012 MACK GRANITE-GU713 (INOPERABLE) (A67714)
2012 MACK...
