Ripped off tilt anchor
/ Ripped off tilt anchor #1
SwampmanLA
No good deed goes unpunished, so it seems. Took my 422 to a neighbor's house to move some dirt and ripped the tilt anchor off the frame. Got it back to the shop and found that the anchor is welded to what looks like 3/16 plate with no bracing directly behind the anchor point. Bracing is a bit on either side of the anchor point so the plate the anchor is welded to is taking the load and flexing. This setup is prime for fatigue cracking and that is what I think happened. As I weld it back in place I have to figure a way to add in some bracing.
/ Ripped off tilt anchor #4
Has this happened to anybody else? First time I think I've seen it. Got me thinking maybe some bracing added on would be a good idea as I'm approaching 1000 hours?
/ Ripped off tilt anchor #6
I had this happened to one of my lift arms. I took the piece that broke off and ground it to where it would easily slip back through the hole with a good gap to give plenty of weld penetration. I took the piece that broke off and then welled a larger than the hole piece to that broken off piece. Put it through from the back and pull it tight with something and weld up the gap from the front penetrating all the way through to the new flange plate.
Check out this post by me stray Lift arm mount bracket (ripped out)
/ Ripped off tilt anchor #7
Sorry Carl, but I must admit when I saw the title of this thread, I thought for sure it was you!
Ken
/ Ripped off tilt anchor #9
I have long since known that the truth hurts..... I feel fortunate 2013 I only nearly burned up my tractor, completely destroyed the bearings and shaft in my mower, destroyed 3 tire tubes and one tire.... It was a quiet year.... I do think I am forgetting something though....
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
2006 Isuzu NPR Box Truck, VIN # JALB4B16567020383 (A65563)
2006 Isuzu NPR Box...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
2003 Ford F-550 Pickup Truck (A66408)
2003 Ford F-550...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
