Right or left handed thread?
/ Right or left handed thread? #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I need to remove the blade carrier bolt from a 5ft. Woods Cadet slasher, the one that holds the blade carrier on the splines. Is the thread right handed or left handed.
Many thanks for any help,
Stuck
211 views so far and no answers. Now I feel better about not knowing myself.
/ Right or left handed thread? #3
Hey, 211 views in less than an hour. Not bad.
I'm guessing everyone is reluctant to commit as I am. If I said, put an impact on it and try to turn it, and it twisted off, I would clearly be corrected as having given bad info.
If it were mine, I'd secure the blade shaft from turning. Then put a long handled rachet or regular breaker bar with a cheater on the bolt and try to remove it assuming right handed thread. By feel I would know if I was going the right direction, hopefully before twisting it off.
If I were reluctant to try that, I would contact Woods and ask them.
/ Right or left handed thread? #4
Can you see the end of the bolt/stud? Which way are the threads pitched?
If it the blade/hub rotates clockwise pretty good chance the threads are RH, vice-versa if it rotates counter-clockwise.
/ Right or left handed thread? #6
Well, I didn't comment because I have no knowledge of your slasher and I haven't had to do anything with the blades on my own... which is a Fieldquip... which you wouldn't have any knowledge of 'cause it's made in Queensland.
Off hand, I'd go with the standard Lefty-Loosey Righty-Tighty mantra.
/ Right or left handed thread? #8
My old Woods hog is Right hand FWIW :confused3:
Thanks for all the answers. I want to get the carrier off so I can weld a nut to a broken off bolt that retains the blade pin. I may just drill it out through the access hole and rethread it or drill all the way through and put a nut on it.
In answer to the questions I can remember, looking at the carier from the bottom, it appears to be left hand rotation (this kind of thing fuddles my brain) and I can't see any threads, a bolt into the splined shaft, similar to on a push mower, seems to be what holds the carrier on.
It's interesting how they keep the bolt from working out. A washer with an off center hex hole fits around the head of the bolt and is tack welded to the carrier.
/ Right or left handed thread? #10
My woods M5 5 footer is right hand threads. If its like mine ? look very close and scrape off and clean very good the end of the shaft and the nut. Mine has a round washer about 3/16" thick, the round part is the size of the housing with a cut out in the middle the size and shape of the nut. After the nut is tightened the 3/16 thick special made washer is placed over the nut then tacked welded on. I know this sounds far fetched but thats how mine was installed from the factory. After the locking type washer is installed it looks like a small nut is protruding but its a large nut after you remove the locking part. I just took a grinder and barely ground the spot weld off then replaced it the same way. Now for the kicker my dads Woods 5 footer don't have that lock. Mine has the slip clutch and his has the shear pin is the other difference.
/ Right or left handed thread? #11
I just reread your post # 9 and I see now you aleady know about the welded on locking washer. You also worded it and described it waaayyy better than I did and it is a right handed thread. I going to learn how to describe things in writing one of these days.:confused:
Steave,
Your description was spot on. Those Woods mowers must run in families. My granddad had one too. I took the carrier off of it over 40 years ago and it didn't have the tack welded retainer either. I really appreciate your advice on that crazy thing. I'd looked at it briefly and it wasn't until I had a second look that I figured out what was going on. Today I remembered that I have an extra heavy breaker bar that I loaned to my brother. I'll probably use that and a cheater next week and see what happens.
Steave,
I forgot to thank you for the magic answer when you confirmed that the thread is right handed. I thought there must be someone on the forum who'd pulled a Woods blade carrier.
/ Right or left handed thread? #14
I have only removed one carrier from a bush hog and it was standard right hand threads. I suspect all bush hogs have right hand threads as they all turn the same direction. I have found that an impact removes hard nuts from bolts much better than brute force (as in cheater bar). I bought a HF 3/4" drive impact just for my tractor and equipment needs. It removed the bush hog nut with ease. It supposedly has 650 Ft. pounds of torque but I doubt it delivers that. I had to reduce the air input size from 3/8" to 1/4" to match my hose so I doubt it delivers the max breaking force but it still moves anything I have put it on so far.
/ Right or left handed thread? #15
When I was trying to remove mine I couldn't imagine why the bolt head only had a small space to get the wrench on it. After a few tries is when I discovered the locking device. I like that idea it's simple and safe.
If it wasn't so hard to cut a hex shape in a washer I'd use that idea on other things. I don't like tack welding the nut itself in place.
/ Right or left handed thread? #17
Thanks for the link. Some good ideas here and I usually find the good ideas after I've made a mess trying it my way. :mad:
2013 CATERPILLAR 299D SKID STEER (A65053)
2013 CATERPILLAR...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
84in. Snow or Litter Skid Steer Bucket (A65640)
84in. Snow or...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
PEQUEA TT4100 TURBO TEDDAR (A64277)
PEQUEA TT4100...
