right angle welds
/ right angle welds #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
I have this 30" long 24" wide 1/4" thick metal I want to weld to a similar piece to create a right angle with the two like an "L" with a stick welder and 7018 rod.
I have these little 3.5" "right angle welding magnets" but they're too weak to hold even laying these pieces on their sides as opposed to "upright". They won't even hold enough for a few stitch welds.
I was thinking about getting a couple of those right angles,LISHUAI Strong Welding Corner Magnet, Neodymium Magnetic Holder Twin Pack - - Amazon.com then stitch weld these together until they can stand by themselves and then welding the rest of the bead.
As I do not have a welding table, anything better than what I have planned that is not expensive? (Have seen right angle clamps that cost $140-$200 but I don't want to spend $30 to get this accomplished).
/ right angle welds #2
Are you going to weld on the inside corner or the outside?
Stand them up on end like a book open to a 90 degree angle use your existing magnets to stabilize them and get it all tacked up then weld it out.
Or just a couple of C clamps and a short piece of angle iron at each end.
/ right angle welds #3
Hold it with a square. Tack a couple of spots. Check both sides and adjust. Put a couple of tacks on the other side. Double check for square and start welding. Do a little then a little on opposite side. Keep checking as you go in case it starts to move.
/ right angle welds #4
What he said!
/ right angle welds
When you say a "square" you mean like a carpenters square?
You're correct!
Cheez I over thought this. As I'm tacking it and even if it's not perfect, I can always bend it to where I want and keep tacking it until it becomes square.
/ right angle welds #7
Set it up best you can and do some tacks. Hammer then to get the right angle.
/ right angle welds #9
What he said!
What ^ they said.
CATERPILLAR 48" QUICK ATTACH PALLET FORKS (A65056)
CATERPILLAR 48"...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
2022 CHEVROLET GM515 SIVERADO 4X2 S/A FLATBED TRUCK (A67737)
2022 CHEVROLET...
2007 CHEVROLET SILVERADO 1500(INOPERABLE) (A67714)
2007 CHEVROLET...
2010 John Deere 4720 58HP 4WD Utility Loader Tractor w/ Titan Aerator (A66734)
2010 John Deere...
master diesel generator (A64553)
master diesel...
