Riggin up the lights!
/ Riggin up the lights! #1
JonE
W NY
B2710/LA401
I must have been on the same wave-length as Dan M. and his JD. I just finished putting some work lights on my 2710. I love it and can't imagine why I waited so long to do it. You'll notice from the pic that I can rotate them 360' and up and down. They are 35 watt fog lamps that I mounted on a box from radio shack. Put some foam rubber strips on it for vibration damping and simply drilled holes (in the box that is, not the ROPS) to tie wrap them on. There is a fuse that I mounted in the box that came with the lights. It is a 15a so I decided to leave it in because the work light fuse in the Kubota fuse box is 20a. I am pleased with the install and that I can focus the light on anything fore or aft (or to the sides for that matter) of the tractor. This is going to really help /w3tcompact/icons/smile.gif when I am in the woods in the middle of the night getting fire wood that I procrastinated getting before./w3tcompact/icons/frown.gif
/ Riggin up the lights! #2
JonE,
Nice clean setup you have there.
Is the connection box weather proof also the base of the lights into the box?
Wondering how much the complete unit cost.
Sometimes is kinda nice to work after the sun goes down /w3tcompact/icons/smile.gif more peaceful.
Thomas..NH /w3tcompact/icons/wink.gif
/ Riggin up the lights! #3
Hmmm, I like the box and are those wire ties holding things togather?
Since I need at least one more light and two would be better I'm trying to figure out how I'm going to get it done. My 55 watt forward facing lights are somewhat fixed. It takes wrenches and screw drivers to move the lights. Which I think is a good thing for the most part. BUT, I would like to be able to point lights were I want 'em. I have roughly 11 amps left in the circuit so I'll likely get two 35 or maybe 55 watt lights. But I really need a way to point the lights were I need 'em. The box is a good idea.....
Thanks for some ideas.
Dan
Thanks very much guys!
The total cost (most of which is tied up in the lights) is as follows.
$30.00 for lights (wal-mart including switch and some wire)
$4.00 for box (radio shack along time ago, just had it kickin around)
$1.50 for a couple connectors, tape, ties, and adhesive backed tie wrap mounts
so I guess that makes it around $35.50-$40.
Yes those are really long tie wraps holding on the whole ensamble. There is some foam strips between the box and the rops to dampen any vibration and create a nice tight friction fit.
The box is sealed except where the wires come out on the bottom for the lights. I'm not too concerned however because it is facing down and there are no exposed connections in the box anyway. All taped up and siliconed up.
I really like being able to just reach up and adjust the lights to virtually any position I want and to switch them on and off.
/ Riggin up the lights! #5
JonE
I've been looking at those small lights, nice and compact. Was wondering if they put out about the same light as a 3"x5" or a 4"x6" light, and is a fog light close to a flood light, or something more concentrated in one spot? I would imagine they are halogen.
Bud
/ Riggin up the lights! #6
JonE
nice setup. i'm looking to add some lights to my folding ROPS. i'm going to do something similar, thanks for sharing
your rigging.
kevin..PA
/ Riggin up the lights! #7
Jon -
Nice tinkerin' ! /w3tcompact/icons/smile.gif
I wasn't too interested in such a thing until daylight savings ended. Now I start to see the light. /w3tcompact/icons/crazy.gif
I'll be filing your post and picture in my tinkerin' files for future reference.
/ Riggin up the lights! #8
I found some reasonable work lights @ CT Farm and Country.
They are metal housed Halides in flood or trapezoidal beam patterns. P/N 12281005 (flood) and 12299005 (Trapezoidal).
$14.99
http://www.farmandcountry.com/shop/custserv/default.asp
Their web page is pretty lame, you need the catalog to figure out what is on the web page./w3tcompact/icons/frown.gif
/ Riggin up the lights! #9
I used standard AC junction boxes. The 1/2" knockout on the back is just right for the light mounting stub. Mine are under a canopy, so I didn't use covers for the junction boxes. The only concern I'd have is that the boxes should be somewhat weather proof. Some water isn't going to hurt crimped connectors. However, a box where ice could build up inside could be a problem. I guess salt spray from road salt could be a problem as well.
/ Riggin up the lights! #10
Great looking and very clever set-up. I think you just helped me with a rear lighting problem I've been trying to solve. And with the bunch of snow we had here the last day or two and having spent quite a few hours pushing the white stuff after dark, I'm motivated.
Thanks for sharing.
Bob Pence
/ Riggin up the lights! #11
Great set up! I just posted a question on "owning a Kubota" about mounting lights, should have looked here first. Just wondered how secure those cable ties keep the box.
Joe, I just finished posting a reply to you on your other post.
The tie wraps are very secure, especially with the foam (heavy foam rubber) I put on the box to take any vibration. I think you can probably find a more asthetically appealing box but I had this laying around.
The whole assembly is very light so it doesn't take much to hold it but I was careful not to place the tie wraps over the entire box but throught it in an attempt to make it more secure. (in my mind anyhow)
Glad I could help you and Bob.
They are halogen and they put out a decent flood right where I need it. And if it isn't where I need it, I just move it./w3tcompact/icons/wink.gif
I have to check but they may be 50 watt. I know I said 35 but I'm not sure.
/ Riggin up the lights! #14
I am going to give this job a 8.75 .Very tidy job,i like the small size.
Thanks for making me laugh!!! I just used those lights this AM to snow blow and I love it. I can actually see where I'm going now. I also used them last night to get the blower on(that was a very good idea), which was out in the yard. Just point them down and I can work effectively.
/ Riggin up the lights! #16
I've got Hella trap lights on my truck and tractor and have had them mounted on other pieces of equipiment in the past. I think they far surpass regular tractor floodlights, or (worst of all) off road lights. Hella sells both 55 watt and dual 55 watt versions. I wouldn't bypass the factory headlights since they meet DOT safety specs for on road use, but you could leave the factory lights off for work use if the amp draw would be too high. Remember too that the alternator rated output currect may not be delivered at low RPMs.
Pat Turner
From the Adams Building
Library of Congress
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
Skid Steer Drag Ripper (A65640)
Skid Steer Drag...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
