Rhino lining for battery area?
   / Rhino lining for battery area? #11
POR 15 works great for battery areas.
   / Rhino lining for battery area? #15
Here are some pix of the refabricated bottom for the cowl. The third one shows the fit being checked. I still have a little bit of fabrication left to do, then it will be time to finish cleaning it up and repainting.
   / Rhino lining for battery area? #17
You can also try starting your tractor with only one battery. I put in a good side terminal battery mounted sideways, reworked the battery tray for a GM style battery hold down, and ran the ground cable down to one of the bolts on the starter. Still crowded in there, but one battery gives you a LITTLE extra room under there. My tractor has never failed to start with the one battery. But it is kept inside, hood covered with a sheet, and rocked to sleep each night. Like all good old JD's deserve..... Put a good 'sealed' side terminal in there, and you will not have the acid problems you have with old 'add water' batteries... I also 'lost' the rods that swing out and prop the cowl door open. Just as easy to unhook the cowl half and take it off if you need access in there. Again, more room....
PS: What is that yeller knob for....???? No yeller knob on my 2240....
   / Rhino lining for battery area? #19
So, there are normally TWO 12V batteries in there?
It looks good, Cyril. Did you take it to an auto body shop? What did they
charge for the fabrication?
   / Rhino lining for battery area? #20
Cyril.. Wow, yeller independent PTO....I have the old foot operated two step pop the clutch and break the shear pin PTO. Since you have your cowl apart, you could loose the ether can port below the light switch. I am going to part with mine this afternoon. Never ever have used ether to start my tractor, but I have bumped my knee on it many, many times. Ether is tricky stuff in a diesel, real easy to blow your motor to smitheenies with too much. Most manufacturers don't recommend you getting ether anywhere near a diesel. Just an idea....since you are bored and are NOT WORKING on anything else on your tractor.... :)
[ 3/4" wrench, just crimped the little brass line untill I pull my hood this spring...]
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A55315)
2022 Brush Wolf...
2013 Chevrolet Express 3500 Passenger Van (A55973)
2013 Chevrolet...
2017 Genie GTH-5519 (A53317)
2017 Genie...
