RFM ?
/ RFM ? #1
honeycutt
Vancleave, MS
Kubota B2320, L175, RTV900
I have a 48" BigBee finish mower. When I was turning I hit a stump. Now the mower is locked up. I disconnected the pto shaft and the pto on the tractor still works. I tried to turn the pto shaft by hand but will not turn at all. I looked under the deck of the mower did not see anything out of the normal. How do I check the gear box.
/ RFM ?
/ RFM ? #3
If nothing is blocking the blades, chances are you have one or more broken teeth in the gearbox. You can open it up and look.
/ RFM ? #4
/ RFM ? #5
You have a big bee finish mower.
Please tell me you have a source for parts.
I bought a 60 incher used but it needs some new pulleys.
I have no idea where to get these at.
It cuts great and I really like it. But it could use some paint.
Pooh Bear
/ RFM ? #6
Pooh Bear
/ RFM ? #7
</font><font color="blue" class="small">( Please tell me you have a source for parts. )</font>
Have you looked for it in Google? /forums/images/graemlins/confused.gif
I got 109,000 results.
/ RFM ? #8
/ RFM ?
I have not had to buy any parts yet. But I did buy a new one after my old BigBee 48's deck rusted out. I got it from a local JD dealer for $850.
/ RFM ?
/ RFM ? #13
<font color="blue"> Please tell me you have a source for parts.
It cuts great and I really like it. But it could use some paint. </font>
If you can provide part numbers, we should be able to provide parts. We stock the quill assemblys and a few belts for the finish mowers.--Ken Sweet
Email sweet@scrtc.com
/ RFM ? #14
/ RFM ? #15
I can get belts no problem. I replace it about once a year.
The big main pulley on the bottom of the gear box is worn real bad.
The edges of the pulley V are sharp.
And some of the idler pulleys have some play in them.
Spindles and pulleys and everything else in good condition.
I bought it used for $250 from a neighbor. Does a great job mowing.
Needs sanded down real good and repainted.
Doesn't have any decals or numbers on it that I can see.
This thing sure is loud when your sitting on the tractor mowing.
If someone else is mowing I don't hear as much noise.
But if I'm on the tractor mowing It is LOUD.
I was told it originally came from the Co-Op up the valley.
Thought about taking it up there and seeing if they can ID it.
Pooh Bear
/ RFM ? #16
Pooh Bear
John Deere 772CH (A64126)
John Deere 772CH...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
