RFM loading up
/ RFM loading up #1
NewToy
Ohio
'05 Farmtrac 270DTC
I have a 60" LandPride finish mower and it really seems to get a build up of grass underneath. I scrape it down every other mowing and get 10 gallons of crud that really sticks under there. Has anyone tried spraying PAM or silicone to help keep the grass from sticking? Was wondering if there was some type of concoction made for this? If so anyone tried it before?
Thanks,
John
/ RFM loading up #2
I try to make it a practice to wash the deck IMMEDIATELY after each mowing. It cleans easily then. If you let it dry, then it takes some soaking and scraping to clean it out. Since you have a RFM it should be easy for you to just raise the deck fully and hose it out. No need to get underneath.
Good Luck.
JackIL
/ RFM loading up
JackIL, I took your advice and washed the deck right after mowing approx 6 acres this AM and it definitely saves time. Took about 5 minutes to hose it out good vs the 20 or so mins it takes to scrape the dried junk out of there. I really didn't realize all that stuff was accumulating after one mowing.
Thanks,
John
2015 John Deere 6125R (A64126)
2015 John Deere...
Inflatable Canoe (A64127)
Inflatable Canoe...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2024 Bobcat T650 (A64126)
2024 Bobcat T650...
INSPECTION (A65579)
INSPECTION (A65579)
