Reversed wheel for 15 series
   / Reversed wheel for 15 series #11
If a tractor has reversable wheels it's designed to operate in either mode (bearings, etc.) other than a specific agricultural need to remain narrow in the row, wide is always better. If you use a FEL or certain other attachments, loaded tires is the far better weight placement than a weight box. There are times you'll need that loaded tire weight while the 3pt is holding another tool. I use both for the machines well being and my own safety.
   / Reversed wheel for 15 series #12
I agree with most of your post however to the bolded, there are times when a weight/ballast box is preferable to loaded tires... see the attachment.
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
Polaris Ranger SxS Doors with Bolts (A51573)
Polaris Ranger SxS...
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
2021 JOHN DEERE 8R 370 LOT IDENTIFIER 175 (A53084)
2021 JOHN DEERE 8R...
