Reverse Saftey Switch PTO cut off
   / Reverse Saftey Switch PTO cut off #1
GTSRider
Cub Cadet 3000
I saw the reverse PTO cut off switch yesterday while I was installing a new brake switch on my 3000 Series Cub Cadet.
Now I'm thinking of eliminating it....because I use reverse often around trees.
Would I just run a jumper wire to the plastic plug female connectors ?
Or is it more involved than that ?
I would keep switch so if I ever sold tractor... all safety features would be working.
Pete
   / Reverse Saftey Switch PTO cut off #2
I just bought a 3205 and was under it cleaning, etc and saw what I think is the reverse safety switch. Mine has a metal tab that pushes the switch button. I removed the metal tab but I don't have the tractor back together to see if it worked.
That should work...let me know .
Thanks .
Pete
   / Reverse Saftey Switch PTO cut off #4
You could also just bend the metal tab so it wouldn't engage the switch. If you ever sold it you could always just bend it back.
   / Reverse Saftey Switch PTO cut off #5
It is spring steel, I couldn't bend it far enough to clear.
   / Reverse Saftey Switch PTO cut off #6
It was an idea. Mine's made of metal so it bends really easy.
   / Reverse Saftey Switch PTO cut off #7
Just connect the two wires going into the switch. That switch actually "breaks" the current running through the wire.
2016 VOLVO VNL780 SLEEPER (A59575)
2016 VOLVO VNL780...
LOT: (2) Truck Brake Part #'s 66864B, (2) Truck Brake Part #'s RK8354709E2 (A59076)
LOT: (2) Truck...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
LOT: Flaring Tool Sets, Pipe Cutters, Brake Line Bender (A59076)
LOT: Flaring Tool...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
Club Car Carryall 500 Golf Cart (A57149)
Club Car Carryall...
