Reverse Saftey Switch PTO cut off
   / Reverse Saftey Switch PTO cut off #1
GTSRider
Cub Cadet 3000
I saw the reverse PTO cut off switch yesterday while I was installing a new brake switch on my 3000 Series Cub Cadet.
Now I'm thinking of eliminating it....because I use reverse often around trees.
Would I just run a jumper wire to the plastic plug female connectors ?
Or is it more involved than that ?
I would keep switch so if I ever sold tractor... all safety features would be working.
Pete
   / Reverse Saftey Switch PTO cut off #2
I just bought a 3205 and was under it cleaning, etc and saw what I think is the reverse safety switch. Mine has a metal tab that pushes the switch button. I removed the metal tab but I don't have the tractor back together to see if it worked.
That should work...let me know .
Thanks .
Pete
   / Reverse Saftey Switch PTO cut off #4
You could also just bend the metal tab so it wouldn't engage the switch. If you ever sold it you could always just bend it back.
   / Reverse Saftey Switch PTO cut off #5
It is spring steel, I couldn't bend it far enough to clear.
   / Reverse Saftey Switch PTO cut off #6
It was an idea. Mine's made of metal so it bends really easy.
   / Reverse Saftey Switch PTO cut off #7
Just connect the two wires going into the switch. That switch actually "breaks" the current running through the wire.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
3 Point Hitch Receiver (A57454)
3 Point Hitch...
1994 CAT 322L (A55272)
Year: 2019 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 24,981 Plate: Body Type: 4 (A59230)
Year: 2019 Make...
20ft Driveway Entrance Gate w/ Deer Design (A57454)
20ft Driveway...
2016 MACK CXU613 MID-ROFF SLEEPER (INOPERABLE) (A58214)
2016 MACK CXU613...
