Reverse Saftey Switch PTO cut off
   / Reverse Saftey Switch PTO cut off #1
GTSRider
Cub Cadet 3000
I saw the reverse PTO cut off switch yesterday while I was installing a new brake switch on my 3000 Series Cub Cadet.
Now I'm thinking of eliminating it....because I use reverse often around trees.
Would I just run a jumper wire to the plastic plug female connectors ?
Or is it more involved than that ?
I would keep switch so if I ever sold tractor... all safety features would be working.
Pete
   / Reverse Saftey Switch PTO cut off #2
I just bought a 3205 and was under it cleaning, etc and saw what I think is the reverse safety switch. Mine has a metal tab that pushes the switch button. I removed the metal tab but I don't have the tractor back together to see if it worked.
That should work...let me know .
Thanks .
Pete
   / Reverse Saftey Switch PTO cut off #4
You could also just bend the metal tab so it wouldn't engage the switch. If you ever sold it you could always just bend it back.
   / Reverse Saftey Switch PTO cut off #5
It is spring steel, I couldn't bend it far enough to clear.
   / Reverse Saftey Switch PTO cut off #6
It was an idea. Mine's made of metal so it bends really easy.
   / Reverse Saftey Switch PTO cut off #7
Just connect the two wires going into the switch. That switch actually "breaks" the current running through the wire.
2016 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2016 UTILITY VS2RA...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
Kubota GR2120 (A47384)
Case IH 2388 Combine (A50514)
Case IH 2388...
Richie Water Master 1200 Trough (A50774)
Richie Water...
