Reverse Osmosis Recommendations????
/ Reverse Osmosis Recommendations???? #21
Just a bit of information, the post about DI water is not the same as "Distilled Water." Distilled water is water that comes out of a Tap or River/Lake/Rain and is BOILED into Steam. The Steam is then condensed back into water. It removed pretty much most everything but can "re-condense" other volatile chemicals that COULD have been dissolved in the original boiled water.
"DI" stands for "DeIonized" it is a chemical process that removes IONS from the chemical makeup of the H2O so that is makes up only Hydrogen and Oxygen (H2O) The chemical substance (pure water) is inert for most part but CAN/WILL strip Ions away from other chemicals/materials easily. The H2O coming out of the DI system is then a chemically pure product & will no longer pass an electrical current like filtered or contaminated water will. The standard of measurement for this in the Mega Ohms but inexpensive DI systems will start making 50~500K-Ohm water that is not TRULY that good of DI water. Industrial grades are 1Meg-Ohm (million ohms) to 20Meg-Ohm water and that stuff will eat Stainless Steel up! The 20Meg stuff usually only used in semiconductor manufacturing and in chemical processes. 1Megohm systems are typical in many industrial cleaning, painting or manufacturing processes.
"RO" stands for Revers Osmosis which is a filtration process that takes out pretty much everything but Ions and extremely small particles (stuff that is 0.1micron level is stopped but smaller may make it thru.) It DOES NOT take out all chemicals or dissolved materials that is in water but does take out a great deal of both. It is much better than best wound replaceable type filters and should have a GOOD filter up stream of the filter.
Typically "DI" systems will have a GOOD "RO" system up stream of them to catch all of the 0.01micron and bigger stuff in the water. Then the DI system further filters it and strips out Ions (fine chemicals and ultra small particles are also removed.)
Mark
/ Reverse Osmosis Recommendations???? #22
Mark
Yep... good explanation Mark. For those of you that want to replenish your system with electrolytes such as gatorade, and other energy drinks... there is a reason. DI water does exactly nothing to replenish you. No salts, minerals, potassium, calcium, magnesium and other elements that are vital to your system. You actually dilute your body of necessary elements if you were to drink DI water.
/ Reverse Osmosis Recommendations???? #23
Mark
Received it Friday. Very well packaged and right on time with what they told me when I ordered it. I did notice that it was slightly wet in some of the packaging bags and read that each system is tested for over 8 hours to make sure there are no leaks and defects. I ordered few additional options: A nicer faucet, upgrade to the line size for more volume at the faucet and the kit to tie it into the ice maker. I installed the system in the basement under the sink of my kitchen. This increased the time to install because I has to build a shelf on a wall and drill one hole through the floor into the base cabinet. Without all of that I would think this would have been installed in less than a couple of hours easily. Instructions where very clear and perfect. Clearly written in the US. And this is clearly a US manufactured and supported product using high end filters etc. To my surprise after installing and turning on the water - Zero leaks. My total Dissolved Solids (they send a free meter and free set of extra filters) at the non RO faucet was 106 ppm. At the reverse Osmosis faucet it was 7 - that's a 93% reduction of ....well crap filtered out. I couldn't be happier and although cost more...I feel I received a superior product that will last longer and will have less problems that result in wet floors. Let me know if you have any additional questions
2016 FREIGHTLINER M2 4X2 SA ROLLBACK (A67148)
2016 FREIGHTLINER...
UNUSED PARBREAK AR650 HYD AUGER SET (A65055)
UNUSED PARBREAK...
GENERAC 80KW PTO POWERED GENERATOR (A64278)
GENERAC 80KW PTO...
UNUSED FUTURE MINI EXCAVATOR COUPLER (A65055)
UNUSED FUTURE MINI...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
UNUSED JCT 60" CLASS8-8000 LB CAP PALLET FORKS (A65055)
UNUSED JCT 60"...
