reverse direction
/ reverse direction #21
If you look at the side pintle (swash plate adjustment), the TA15 has 2 mounting screws, the TA19 has 4. Thinking you have the TA15
/ reverse direction #22
The numbers you’ll find stamped on the flat spot on the small cover on the aux vane pum.
/ reverse direction #23
/ reverse direction
thank you for that info. I will check it out first thing in the am and let you know.
/ reverse direction #25
In looking at the parts breakdown that Sundown posted for the TA1515 it does appear that central port block is common for either CW or CCW rotation so should only have to change vane pump.
Been 20+ years since I did that job. Not difficult but I don稚 remember the exact process.
/ reverse direction
even if I had to replace that one it wouldn't be the end of the world, it's not all that expensive, and having a new pump there would be a big plus too.
/ reverse direction
found numbers but they don't seem to do me much good.
/ reverse direction #28
Just thinking outside the box how hard is it to reverse the rotation of the engine?
/ reverse direction #29
A friend has an old inboard ski boat powered by a 289 ci Ford V8. It has a different special cam shaft for opposite rotation
LOOK! (A63116)
LOOK! (A63116)
2004 Ingersoll Rand SS-3 Portable Air Compressor (A61572)
2004 Ingersoll...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
UNUSED WOLVERINE FORK FRAME (A64281)
UNUSED WOLVERINE...
