Retractable Hay Forks
/ Retractable Hay Forks #1
mffarmall
Colorado
Farm Pro 2425, MF 50, JD B, Farmall Super MTA
I am selling two of my tractors and at the same time wanted to buy some forks for my fel. But I will only lift 6 3x9s and travel a total of 10 ft over the entire year. That is a waste of money to buy them. I found that I had four extra 3 point bars. I was going to leave them on my attachments. In the morning I was looking at all the pins and junk that I had from the tractors that I was going to sell (don't sell it if you use it). The sun was shinning through a hole in the fel. If it was not morning I probably would have needed a beer the way my mind raced to a solution to two problems. I ran to Aces and bought some bults and washers (big washers to support the bucket wall). I bolted down the bars on each side of the bucket and then used a grinding blade to cut off the ends (at an angle). I tried to stab a open bale but the end just bent in. I needed to stop the swivel from moving. I always think of getting out the sledge hammer. But I almost ran over two L solid iron scrap pieces that I cut off something years ago and just move around from pile to pile. I ended up using them to cratle the arms on the inside of the bucket. I was able to lift two trailers and a old iron horse trailer (I mean heavy, the guy I bought it from showed me the 38 dents) I just wonder why someone needed to shoot at his trailer? And I lifted a 3x9. The only problem was that now that I had it on it would be months before I would want to take it off. And the last thing I needed was to drive around with spears on the from of my tractor. I was driving back to the shed and I hit a bump pushed the fel up and as it went up the forks folded up into the fel. So I can leave them on (bungy them down) until I need them then I can just pull them down. I will add pictures. Then can support 1200 pounds as long as I'm not going far or fast.
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
213098 (A64276)
213098 (A64276)
Unused 2024 Schulte 5026 26ft. Batwing Hydraulic Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
217982 (A65054)
217982 (A65054)
