Reservoir cleaning
/ Reservoir cleaning #1
Targe911
NH L555
What is the best way to clean out the reservoirs of a slime like substance?
/ Reservoir cleaning #2
Our public water supply reservoir had a bunch slime and we put grass carp in it. They cleaned it up and no problem since.
/ Reservoir cleaning #3
What reservoir ? perhaps your tractor hydraulics/transmission?
/ Reservoir cleaning #4
I just bought one on Amazon for $13…like a reverse grease gun let’s you suck the old junk out of (e.g.,) a gear box or other with no drain port at bottom. Good YouTube video on changing oil in bush hog gear box shows same tool. The stuff in my gearbox no longer resembled oil! More like a milky goop.
/ Reservoir cleaning #5
We used to call it a suction gun
/ Reservoir cleaning #6
I've used diesel fuel to cut the slime and flush it out the drain plug.
I had one transmission/rear axle I used Dawn dishsoap and a pressure washer on first then the diesel fuel.
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
PENDING SELLER CONFIRMATIONS (A59906)
PENDING SELLER...
2019 Ram 1500 Crew Cab Pickup Truck (A59230)
2019 Ram 1500 Crew...
