Requesting words of wisdom
/ Requesting words of wisdom #1
BenRich
Waxhaw, NC
Kubota BX1860
I'm requesting some wise hints/tips from experienced subcompact tractor owners. I've recently purchased a Kubota BX1870 and am expecting its arrival from the dealer possibly next week. I have a few recent hours on my brother-in-law's ancient Iseki and as a teenager I spent several dozens of hours bush-hogging on a Case 930 and an old JD "poppin John". That was back in the '70's.
I did considerable research before deciding on the BX1870 (actually my research was on the BX1860 but I believe the only changes are cosmetic and moving the brake pedal from the right to the left side of the operator deck). The tractor will come with an FEL (LA203), a Land Pride grooming mower (FDR1648) and a 5' Land Pride scraper blade. There will be no mid-mount mower (thus leaving the underside of the tractor exposed).
We live in the Piedmont area of North Carolina on three and a half acres; about half the property is wooded, the other half fields with pasture grass/weeds. I intend to use the tractor for mowing and moderate landscaping.
Herewith some of my questions:
1. With no MMM, would I be smart to get the Bro-Tek rear plate? There will be times I'll be going into low brush.
2. Is the 5' scraper blade sufficient ballast while using the FEL? I'll be using the FEL for carrying dry fill dirt, mulch, gravel, sand and occasional chunks of firewood. I'll also be using it as an occasional hoist (the dealer will be welding a 1/2" chain hook on each upper corner of the bucket); in these instances I envision using it to tug logs out as I'm cutting back on the woods on our property. The scraper blade will be used mainly to pull dirt from one spot to another spot and for leveling.
3. Will the grooming mower perform as an occasional light duty bush-hog? The dealer told me that it would cut rough pasture grass but there is one area (my septic drain field) where I get the seasonal saplings (less than half inch trunk diameter) springing out of the ground.
4. Is there any one (or more) pieces of advise that any of you wished you had been told before you got your tractor and started using it?
I'll be very grateful for any words of wisdom from those of you that have the knowledge and experience I don't have. If anyone asks me a question and I don't respond quickly it's because I'll be outside most of today planting tomatoes, okra, late beets, cucumbers and more green beans. Thanks very much in advance.
Ben
/ Requesting words of wisdom #2
Answers:
1) yes
2) probably
3) probably for what you described, but 2 passes may be needed the first time. But pruning shears will make quick work on those small saplings, thus taking the stress off the mower.
4) keep FEL loads as low to the ground as possible, and travel slowly, with your hand on the FEL joystick to drop it quickly if needed.
Be careful
Read the operators manual several times. Become familiar with every page.
Have fun using your new toy.......er tool :)
/ Requesting words of wisdom #3
I am certainly no expert, but here is my opinion, we got our first BX, a 2200 in 2003 and a BX2660 in 2008; still have both.
Even with the improved HST fan protection plate added a couple of years ago, I would still go with a protection plate/plates from Bro Tek or Bxpanded. I have Bro Tek, but look at both to see which you prefer.
It depends on how much it weighs, but I suspect it won't be sufficient as mine isn't. Some build a ballast box to add weight I use a box scraper which is heavier than my blade. If you find you need more weight, it is easy to hang something on the box scraper. I suppose you can on the blade, I just prefer the box scraper as I can move much more dirt with it. As to the hooks, I prefer them welded to bucket in line with the loader arms.
There is a difference in "can" and "should", I suspect the RFM will cut what you describe, but I will hold off on recommending it. Maybe someone else can speak to this.
Not that I can think of, but if I do, I will post back. Oh check all fasteners and your front axle fluid after a few hours of use as they tend to settle in after a bit and needs to be topped off.
JOHNTHOMAS
has a thread on 50 hour maintenance and has owned a bunch of these small tractors, so read some of his old threads and other BX owners. Good luck and enjoy your tractor, these are very tough capable little machines.:thumbsup:
/ Requesting words of wisdom #4
1) You will eventually go into the woods with the tractor. Some kind of protection for the fan is advisable. If you can't fabricate a plate then Bro-Tek works.
2) The dealer should have filled the rear tires with water for ballast. The LA205 FEL will not lift much so water in the tires works well for ballast. You will soon know if ballast is needed if on the first heavy lift you need to go into 4WD to move. As said, always keep a heavy load low just in case. A rear blade does work as ballast but severely limits maneuverability, especially in the woods.
You may want to look into buying a Carry-All to carry ballast on a pallet. Then you can use it to do other jobs as well.
3) A finish mower is just that. More of a lawn maintenance tool or to make a pasture look like a lawn. You will have to go s-l-o-o-o-w in heavy grass. Check Craig's List every now and then to see if you can come up with a 4' used bush hog. It will make things go much faster and you can use the finish mower properly. A bush hog (rotary mower) can also be used in the woods for clearing. The saplings over your septic lines won't have a chance with a bush hog.
4) Post back when you run into a situation where a second opinion may help out. The TBN guys are very helpful and have a wealth of knowledge. And don't forget photos.
You don't mention the tires. Turf tires probably but you may have R1s. The turf tires are going to be an issue if trying to drag logs.
If the dealer puts the chain grab hooks on the ends of the bucket then you are in for trouble. Never pull or lift from one end. It will cause tractor instability and has the potential to tweak the FEL out of alignment. The grab hooks need to be even with, or inside of, the boom arms of the FEL. On my BX2200 I have one on the top center of the bucket and one on the lower back of the bucket. Lifting from those points makes for a stable lift.
Soooo....
A) Have the dealer fill the rear tires.
B) Have the grab hooks welded in the middle. This will require that the top bucket edge be reinforced - I used a couple of feet of 1/2" (or maybe it was 3/4" pipe) welded under the lip. Whatever fits snugly.
EDIT: Darn you TripleR. You slipped in your post ahead of mine and stole my thunder. ;)
Thanks guys for the excellent responses and advise. (I've come inside for a quick lunch and decided to see if anyone had responded.) I'll talk to the dealer on Monday about the placement of the chain hooks and water in the rear tires. The tires are in fact turf tires; the dealer had suggested those when I told him some of the work would be in the back yard and I would be crossing one side of the front yard while moving fill dirt. I'll look into ordering the Bro-Tek plate as soon as possible... I'd prefer to have that in place before I operate the tractor. Thanks again.
Ben
/ Requesting words of wisdom #6
Your welcome.
If you have any more questions, don't be afraid to ask.
And welcome to TBN
/ Requesting words of wisdom #7
I'm in agreement with what has been said.
Definitely get a skid plate. The Bro-Teks are nice, you can also take a look at the BXpanded.com Under Armor. Easy install on and off if need be.
I wouldn't trust the weight of the scraper blade as ballast, particularly when the loader is full and several feet off the ground. My guess is that blade weighs less than 300lbs.
Let the finish mower be just that, a finish mower; costs too much to be using it as a brush cutter.
Other suggestions: check all nuts and bolts after a few hours of operation. As mentioned, check the front differential fluid after 5 - 10 hours; check all fluids for that matter. Get yourself a bucket hook or two, you'll need it, trust me. You can purchase bolt ons but mine is welded onto the top of the bucket. I do have a brush mower but at times use a chain and BrushGrubber to pull saplings and other brush.
/ Requesting words of wisdom #8
Ben
Welcome to TBN. Remember the proper etiquette here though. We gotta see it to believe it. :)
I would add my vote to what Triple and GW have said. BroTek and BXpanded both have great under-body protection. BroTek's actually comes as 3 parts and covers the whole underside while BXpanded's appears to cover more than BroTek's (if rear only). And BXpanded's can come off easily and quickly. Your choice, either will save your bacon over no "cup" at all. I chose the BroTek because my tractor is older and BXpanded didn't seem to offer one to fit. I only went with the rear plate, but then I added my own protection forward using the mower lift on the rear of a piece of 1/2" inch real plywood (not this osb stuff). It goes forward about 3 inches past where the front drive shaft starts to come down. Some guys reported that they got sticks up into the radiator fan (and that's why BroTek added the 3rd plate). I didn't see myself getting into stuff that wicked, but a small stick won't ever push through my plywood either.
Good advice on the hooks too. Keep them inside and try to use both at once to help keep the balance if lifting. You're pretty far south, but keep in mind that water freezes. Maybe a little washer fluid or RV antifreeze would be in order as well.
I learned to drive on my dad's 51 Model A JD. Then I graduated to a 730 Case. I was replaced when I went to college with a 930 Case, but I still got pretty good hours in on it. Sounds like we had similar upbringing. :) Enjoy that new tractor!
Sent from my iPad using TractorByNet
/ Requesting words of wisdom #9
I hope you were misquoting the size of the chain hooks. No way in h$ll will you need a 1/2" chain on a BX more likely a 3/16 or even smaller will handle all that little tractor will lift. If for instance you have some 5/16 or 3/8" pull chain, you could put a 3/8" chain hook on and use both but you would be way overkill on the chain and really be limiting your lift by at least 40 lbs on a 20 foot long x 3/8 chain. Hooks should be placed at the corners or rather in line with the lift points of the FEL bucket, and always use both hook so you are equally applying force to both sides. Never pick from on side only to prevent tipping your tractor. Hooking your chain in a V with the bottom of the V being the attachment point of the object lifted and the top of the V being the attachment point on the tractor. Hooking in the middle of your FEL bucket is why you see so many bent lips on the FEL. Before you place one in the middle, put some reinforcement angle or other material across the lip and then you will be OK.
/ Requesting words of wisdom #10
Soooo....
You know what they say about great minds nd I left out the part on filled tires, we did that on ours and it sure helps.:thumbsup:
Again, thanks lots for the excellent advise. I was unaware of BXpanded and have checked out their skid plate. At least they have a price listed and the price seems very fair to me. I wasn't able to find a price on the Bro-Tek plate but had read a past thread where it was mentioned the rear plate cost $180... and this was back in 2012 I believe. The dealer is not charging me for the chain hooks and when I asked him about this being done he said they do it for most their customers, who are working farmers. I'm actually have a lot of confidence in this dealer; I know several people that use him and he came with multiple recommendations from people that do not know each other. They've been in business in this area for almost forty years and most of their mechanics have been with him for thirty years or more.
Again, thanks for the words of wisdom. I'm going back out now to do some more garden planting.
Ben
/ Requesting words of wisdom #12
Ben
Have fun. We had snow here this morning, so no planting yet.................Looks like 'Global Colding' is taking over :laughing: :laughing:
/ Requesting words of wisdom #13
Ben, welcome from another 8 year BX owner who lives not far from you. Our place is in Summerfield, just north of Greensboro. You've made a good choice for equipment and there's good advice here for you so far.
I agree 100 percent about the need for rear ballast... both in the tires and on the back end.
While I do not have skid plate protection on my BX and have been OK so far (accident waiting to happen, I suppose), these little units are very low to the ground and have lots of exposed hardware, including the fan, so the protective plates are indeed a good idea if you're headed into the woods or any overgrown area.
The other advice I'd add is concerning lateral stability. On its own, the BX is very stable due to its low design. But the FEL changes the picture dramatically. If you have 400+ lbs of something in the bucket (plus another 100 for the bucket itself) lifted to any significant height, it doesn't take much to get the whole tractor tipping to one side or the other. Transport any loads in the FEL as low to the ground as possible, avoiding bumpy or sloping terrain. After you've been using the BX for a while, you'll gain a sense of how it is balanced as you operate it, but be really cautious as you learn.
Share some photos when your new BX arrives!
/ Requesting words of wisdom #14
You want to pull log's etc. ? Do it from the three point on the back. You can get a tool bar welded up that works well or you could remove the blade only from the back blade and use the frame work to tow. Weld on some hooks and you are good to go.
Now for the towing procedure!! Make sure the bucket has weight in it. Dirt or rocks work real good. Lift up a little on the three point to get weight ( ie. traction ) on the back wheels and lift the front of the log off of the ground and tow away. Make sure the frOnt wheels stay on the ground as this setup has a high tow point and could cause a backflip if not done properly.
Turf tires will do fine. The three point will put lots of down pressure on the rear tire giving good traction.:thumbsup:
If you wish I can post a few pictures of a Kubota B7100 HST at work. I have to use a different computer to do it.
Note: no words of wisdom here. Just what has actually been done!:thumbsup:
Thanks for all the good advise. I do have a question regarding water in the tires. I understand this adds weight which acts as a counterbalance to the FEL. I would imagine it also adds a bit to traction (though with turf tires that might be marginal). My question is, how does this impact handling? When I test drove the 1860 I was very surprised by how "nimble" it felt, despite it's feel of "solidity". Will water in the tires create a certain amount of inertia or drag to the 1860's normal handling and, if so, is this at all a negative effect?
My other concern is tire wear and maintenance. Does water in the tires increase the wear of the tires?
In the maintenance department, if I spring a leak in a water-filled tire what is the process to get the leak repaired? One reason I decided on a SCUT was the knowledge that I would be able to do most of the maintenance myself, including removing the wheel and taking it to a tire repair place in the event of a leak. If the tire is filled with water will it be possible for one (beat up 56 year old) person to take the wheel off, wrestle it into the back of my aged SUV (or borrow somebody's pickup) and take to any tire dealer to get it repaired or will I have to drive it thirty miles to the dealership for repair/refilling? I guess this is a question I could ask the dealer when I call tomorrow, but I'd still be grateful for any sound advice and/or experience from those on this forum.
Ben
/ Requesting words of wisdom #16
When my BX2200 got its FEL the dealer filled the rears with water. There was so little difference in handling and feel that I had to check to make sure that water would come out of the fill valve. In other words, the difference between filled and not filled is so minor that it will not be noticed.
The filled tires will probably wear a little faster if you drive on a hard surface. But the turf tires seem to wear incredibly well. After 600 hours the rear tires on my BX look unworn. The front tires take much more wear.
Most large tractors with filled tires are serviced by mobile tractor tire trucks. The tires are repaired in place. That is always an option.
For smaller tires it is possible to take the tire off by jacking up the tractor to JUST the right height and roll it off the axle. Put the fill valve at 12 o'clock and let out the air pressure. Then rotate the hole to the top where there is no water. A tubeless tire plug can be used to plug the hole from the outside using plenty of goo (repair glue). A kit for this task is inexpensive.
The bottom line is that it is very rare to have a puncture in these tires. More often flats are caused by leaky rims or deteriorating rubber sidewalls. At that point it is a simple task (well, sort of) to put in a tube. The tube can be filled with water as well.
/ Requesting words of wisdom #17
If you have concerns about filled tires, you can get weights, one of ours has filled tires and another has weights.
I want to thank all of you for your responses and good advise. I'll be calling my dealer tomorrow and bring some of these suggestions up with them. As I mentioned earlier, this dealer has an excellent reputation among those that use them (and continue to use them). Thanks again.
Ben
