Repower DR chipper shredder
   / Repower DR chipper shredder #1
yardtime
Simplicity legacy. Wheel horse work horse
Need to replace the motor on my chipper . It is a Briggs 800 series . Having a heck of a time locating specs for shaft size , key way etc.. The model numbers on the valve cover does not bring up any luck on all the sites I致e tried . Also can稚 tell if it has gear reduction or do I really need it. The unit belonged to my father-in-law who passed five years ago . The chipper model Is CST 800. Looking for advice on what motor I can put it . Trying to stay low on cost , a new comparable chipper is around $800 . Wouldn稚 be cost effective to spend more than $300 on a motor . I have over five acres so I burn too and chipping/mulching is more of a convenience.
Thanks .
   / Repower DR chipper shredder #2
Have you tried contacting DR directly, they should have those specs, and probably have replacement motors. Good luck
   / Repower DR chipper shredder #3
You can pull the engine off and measure the shaft size . Hf sells cheap engines ...
   / Repower DR chipper shredder #4
X2
"One measurement is worth 1000 expert opinions."
If the output shaft does not align with the crankshaft it has a reduction gear.
So I called dr and they could only give me key way specs , 1/4 x1 1/2 . I’d like to go with an hf motor, cost wise , but it looks like it is too short and squat hitting the mulched hopper chute . I may be stuck with a Briggs replacement. $$$
I checked out the hf motor . I think the 3/4 shaft is a match but the key is 3/8 . Everywhere I turn I may be stuck with $$$$
   / Repower DR chipper shredder #7
Thanks .
Could you post the model type and code from the engine and I will see what I can find for specs. Should be located on the side of the valve cover.
   / Repower DR chipper shredder #8
If it will work just get a new pulley with the correct key way size.......
   / Repower DR chipper shredder #9
Where are you located I can get honda motors at cost.....
It’s an 800 series model #
1263 12 0141 B8
I think the code is
100 805 88
I live in East haddam ct .
Thanks all , you’re awesome with the responses !
2022 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A51219)
2022 FREIGHTLINER...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
JLG 1255 Telehandler (A51039)
JLG 1255...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
2013 Chevrolet Tahoe SUV (A49461)
2013 Chevrolet...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
