Replacing starter and ignition coils on PT422
   / Replacing starter and ignition coils on PT422
I am sending a few pictures.
The one of the fuel pump side does not really give you an idea of the advantage of this removal, but by removing the fuel pump I was able to slide the engine and bracket about two inches towards the fuel pump side and then was able to remove the start which is on the other side.
This picture shows the starter motor side of the engine. The starter motor has already been removed. Please note that one ignition coil is visible. Also both front and back hydraulic pumps have been unbolted. It may not be necessary to unbolt the back pump. I have rebolted it with one bolt and will try to finish the job with it installed. Also note that the gas tank and gas tank bracket have been removed.
I am not quite sure how to get to the coil on the fuel pump side of the engine, but I will investigate this further once I have replaced the starter motor side coil and the starter motor.
This is a picture of the gas tank. Pretty boring. Please note that on the left side is a little white valve. I had previously installed this so that I would not have to drain the fuel tank when I removed it. This saved me a little time.
So far I have not had to disconnect any hydraulic lines.
   / Replacing starter and ignition coils on PT422 #14
Hey BobRip,
What is the part number of the NAPA filter that you are using for a hydraulic filter.
Duane
It's NAPA 1551. NAPA crossed referenced it from the number of the original filter. I have been using it for four years.
Bob Rip
I called Jack Gawecki of Robin today. I gave him the model number off of the old starter and the engine model number, spec number, and serial number. I sent him a fax with this info and my address and then called him back. He stated he would send out a starter and two ignition coils today. My hat is off to Robin. The tractor is four years old and they still send me parts free.
Jack stated that I should be running synthetic oil in the engine and transmission to help with cold starting.
I have one of the valve covers off and it looks very clean inside. I will be adjusting the valve clearance while I have it off. Robin recommends this at 500 hours and I am over 400.
Again, thanks Jack for the support. It looks like Power Trac made the right decision in going with Robin.
I thought it might be a good idea to attach a picture of the starter. The left end of the starter goes towards the front of the tractor. You can see the 0.8 KW rating. The new one is 1 KW. This is about 25% more power and probably torque.
The label on mine was coated with dirt and I could not read or see the label until I removed the starter and wiped the dirt off. The label is up and maybe you can see it with a mirror when the cylinder baffel is on. I did not try that.
I got the new starter and ignition coils today. It took about a week. I started the installation of the new coils. It looks like the gap between the coil and the armature is about 0.014 inches. Does anyone know exactly what it should be.
I hate to set it wrong.
BobRip
   / Replacing starter and ignition coils on PT422 #19
I checked my notes. Jack told me .012 to .020 was the spec. That is what I used and they work. Replacing the coils is an interesting project isn't it?
DHS
Thanks again. Yes this is tight. I had to remove the battery last night. I have a lot of bolts out right now. I am going to adjust the valve backlash and clean the cooling fins while I have it apart.
Bob Rip
1995 Generac 94A04738-S 125 KW Towable T/A Diesel Generator (A55851)
1995 Generac...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
250ft Roll of Copper-Clad Aluminum Building Wire (A55852)
250ft Roll of...
2012 Freightliner M2 106 Altec AM650 50ft. Bucket Truck (A55852)
2012 Freightliner...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
