Replacing my Murray! Need advice!
/ Replacing my Murray! Need advice! #21
</font><font color="blue" class="small">( Evening,
After three years of below average service, I think my Murray lawn tractor has finally given up the ghost! Better said, I don't want to spend any more money on this pig to bring it back from the dead!
I was playing around with getting a finishing mower for the B7800, but decided this would be overkill. Also, I've got a pile of yard-size attachments that would be obsolete if I don't replace the lawn tractor. So I think I'll replace the lawn tractor with something that can offer me a little bit better dependability (or any for that matter!). I was set on an 18.5hp Husqvarna with a 42" deck and hydro tranny, until the last time I went to TSC. They sell a Huskee Supreme 23hp with a 46" deck and hydro for about $350 less than the smaller Husqvarna.
Husqvarna quality speaks for itself (I have their chainsaws), but I don't know anything about the Huskee brand at TSC. /forums/images/graemlins/confused.gif Does anyone have any experience with the TSC brand? I like the tractor, and the price is right, but I don't want to make another Murray mistake!!! /forums/images/graemlins/mad.gif /forums/images/graemlins/blush.gif
The engine is a B&S with a spin off oil filter, so that seems pretty high quality, but for all I know the rest of it could be a re-badged Murray!! /forums/images/graemlins/confused.gif
I like the Huskee, and the price to features ratio is right, but I don't want to buy another lawn tractor in another three years! Help, should I go with the HUSKEE or stick with th"HUSKY"?? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif )</font>
You might want to check this link before you buy a Huskee. Might be interesting to MTD owners also.
Complaints
/ Replacing my Murray! Need advice! #22
</font><font color="blue" class="small">( some are going to disagree, but i bought a CRAFTSMAN 18 HP GT AND IT IS STILL GOING STRONG 14 YEARS LATER. , and i use it a lot, probaly over 100 hours a year, only thing i ever had to repalce othe than normal wear items was a starter motor about 6 years ago. )</font>
I would rather have an old Craftsman than a new one anyday. They are not the same animal now. Back then they were a premium machine. Glad you have had such good luck with yours!
Slam
/ Replacing my Murray! Need advice! #23
The electric clutches in riding mowers are an expensive repair that seems to happen a lot. I prefer the old belt drive types of decks. Simpler is more reliable and cheaper.
/ Replacing my Murray! Need advice! #25
Slam,
I guess Murray has gone downhill as most of the companies have, but they didn't have as far to go downhill as some other companies. I guess some of the other companies have now dropped to where Murray was years ago. I always hate it when you buy something that lasts well and when it is time to get another one it has turned to junk. This includes a LOT more than just mowers. Guess I will just keep re-furbishing the older better ones as long as I can get parts.
Sounds like some of those problems were Briggs problems, who just bought Simplicity /forums/images/graemlins/frown.gif
/ Replacing my Murray! Need advice! #26
</font><font color="blue" class="small">( Slam,
)</font>
SlowRev, It is bad man. I hated to rain on anybodys parade but the fact is were all gonna have to be rich to buy a **** lawn mower before long. I picked up the engine failures in the link also and while I am not a big B&S fan I don't blame them for all the problems noted. On four occasions I have seen the big twins come in that had supposedly "blown up" for no apparent reason. In all 4 cases parts of the air filter were sucked into the engine! This only happens for one reason. A filthy, clogged airfilter. That's just one scenario. Then there was the guy that thought it was OK to run used motor oil from his truck in his mower cause "it's just a lawn mower". Sheesh!
Slam
/ Replacing my Murray! Need advice! #27
Slam, I too work on mowers. Mainly riding mowers. Mainly MTD, AYP, Murray/Noma with a few others thrown in. How about a few of the problem areas:
Cheap spindle assemblys, less than stout blades, cheap steel pivot axles (especially MTD), cheap bushings (actually nylon insert type things), Bolts that vibrate loose (check the transaxles, they come loose & create all kinds of problems), deck problems (especially uneven cut when on level, making turns, well, most of the time!) Hoods that literally fall off. They are plastic & the heat from the exhaust melts the plastic on the front. I can go on & on as you well know.
/ Replacing my Murray! Need advice! #28
Thanks for the info on the Air cleaner thing Slammer., I was not aware of that problem, did not seem to be an issue on the older briggs. My father in law almost never changes the oil or cleans his air cleaner on his old murray unless it won't run. Told me the other day "you only need to change the oil every 5 years or so", WOW! I guess he is just blessed /forums/images/graemlins/smile.gif
/ Replacing my Murray! Need advice! #29
Molerj, Agreed 100%! You have perfectly described the ongoing misery that is Murray. /forums/images/graemlins/cool.gif
Slam
/ Replacing my Murray! Need advice! #30
Slowrev, GEEEEEEZZZZZZ!!!! He must be blessed! Sadly he is probably the typical consumer. Present company excepted of course! /forums/images/graemlins/laugh.gif
Slam
/ Replacing my Murray! Need advice! #31
After re-reading my post above I decided that it might be deemed disrespectful to the consumers out there that I make my living from.
What I meant in more detail is that if "we" would clean our airfilters every time we mow (yes everytime) and change "our" oil twice per season, and keep the debris cleaned out of "our" decks and engine compartments "we" would get a lot more use from "our" equipment. If everyone did this it would make a phenominal differance in the longevity of engine and machine.
Also only buying equipment with grease fittings and heavy blades that can be sharpened regularly would be a huge cost saver.
Slam
/ Replacing my Murray! Need advice! #33
</font><font color="blue" class="small">( </font><font color="blueclass=small">(
Sounds like some of those problems were Briggs problems, /forums/images/graemlins/frown.gif
)</font>
I picked up the engine failures in the link also and while I am not a big B&S fan I don't blame them for all the problems noted. .
Slam )</font>
I wil never buy another MTD product nor will I ever Buy anything with a B&S motor.
I bought a MTD with a B&S motor.
Have had nothing but trouble with the motor and the tractor isn't far behind.
Nothing like getting 2 screwings for the price of 20.
/ Replacing my Murray! Need advice! #34
</font><font color="blue" class="small">( cheap steel pivot axles (especially MTD),
1* cheap bushings (actually nylon insert type things),
2*Bolts that vibrate loose. )</font> ~~~~~~~~
1*I could not keep these on the left side finally wore the hole way over size and out of shape.
A welder friend and I Discarded the nylon inserts and plastic bushings and replaced that junk with a piece of pipe welded to the top and bottm holes in the axle packed it with grease & put the wheel back on. This left side will probably outlast the factory right side 10 to one.
2*You forgot the front axel bolts that fell out of mine so when I backed up I backed the tractor right off of the front axel.
/ Replacing my Murray! Need advice! #35
Consumer Reports lists the JD L series as top rated. Home Depot has em and they won't break the bank. /forums/images/graemlins/cool.gif
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2012 EAST 30' DUMP TRAILER (A64277)
2012 EAST 30' DUMP...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
3-gal. chemical inductor, Coal Valley, IL (A65640)
3-gal. chemical...
