Replacing Logging Winch Cable
   / Replacing Logging Winch Cable #1
BILLWEST
I have a fransgard winch and need to replace the cable. I am not sure how to get the old off the drum and attach a new one. Anyone have experience with this? I can open the access plate but i just cant see how its attached in there. Must be a simple answer - thanks.
   / Replacing Logging Winch Cable #2
I think if you pull unwind the cable it will becoem obvious. I suspect if it's liek the ones I have changed it's a keyhole that the ferell on the end of the cable clips into.
Andy
I have unwound it all the way and taken off the plate which I believe is all you need in order to access the inside of the drum. It appears the cable tightly wraps 180 degrees around something and of course is tighter than heck and its not possible to just push it backwards with your hand. SO I am hesitant to just start banging on it with a rod or something until I ask a few who may have done it. thanks
   / Replacing Logging Winch Cable #4
I am not familar with your winch, but I have had to take a torch and cut the dead head end at the winch, just watch out, be careful. Usually after you cut the cable, you can tell how it goes back.
Good Luck
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A51222)
1968 CHEVROLET C10...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
