Replacing engine Coolant on B2620
/ Replacing engine Coolant on B2620 #1
Amateur
Chambly, Quebec, Canada
Kubota B2620 HSD
Hi, I want to replace mu engine coolant and I am not sure what to use. I just buy this engine coolant (Zerex Pre-Charged Antifreeze/Coolant) and I want to know If it is what I need. I have a b2620.
Thanks.
:confused:
Zerex Pre-Charged Antifreeze/:confused:
Protects diesel engines from rust and corrosion and cylinder liners from liner pitting and cavitation
/ Replacing engine Coolant on B2620 #2
50/50 mixture ethylene glycol and water. Which is in most antifreeze that i know. I use Prestone.
/ Replacing engine Coolant on B2620 #4
The Zerex will be fine for your tractor,although a little overkill.Your Kubota engine does not have cylinder liners so the liner protection is not needed.Regular old green coolant mixed 50/50 with distilled water would match the factory fill-renew every two years.Good Luck!
Planter Seed Plates (A65640)
Planter Seed...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
Lot of (15) Hedge / Black Locust Posts (A66408)
Lot of (15) Hedge...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2016 BOBCAT E35I MINI EXCAVATOR New Hydraulic Thumb (A62613)
2016 BOBCAT E35I...
Landhero 12-Ton Hydraulic Shop Press Machine (A66408)
Landhero 12-Ton...
