Replacing CK20S light switch ?
/ Replacing CK20S light switch ? #1
Slackdaddy
Land of the Free
Kioti CK20HST
My 2005 CK20S headlights, tail lights don't work, only the right turn signal works. Both rear flashers do work.
I am guessing the Light Sw is bad?
How do you remove/replace this switch, did a forum search and not finding it.
Thanks,
Nick
/ Replacing CK20S light switch ? #2
My CK20 is older than yours, but based on what I have seen on it you will need to remove the dash or at least the cover plate below the dash. Michigan Iron may have an exploded view of the dash in it's parts catalog that might help.
Cheers
Rancho
/ Replacing CK20S light switch ? #3
From memory the wiring goes underneath to the rear. Just check your connectors before pulling the switch out.
/ Replacing CK20S light switch ? #4
I would suspect fuse or corroded or broken wire before switch. I sure wouldn't order one before diagnosing the problem first. The chances of it being the switch are very low.
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
(32) Kinze Seed Tubes (A65640)
(32) Kinze Seed...
